Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Diesel Pre Filter plus Factory Filter
    Nov 2018
    Newcastle NSW
    2006 TD42 DX Patrol Ute
    G'day everyone,
    I'm new to 4x4, have only had my rig for a couple of years and as far as I know it's still stock.
    I'm lined up to have a pre-filter (professionally) installed.
    The local shop uses the Flash Lube brand with the clear bowl which I think will do.
    I'm wondering though ... is it a simple matter of them hooking it up, plumbing it in and all will be well?
    I've been reading about lift pumps being necessary & as embarrassing as it is to say it ... I wouldn't know if I have one yet from factory or not.
    Just thought I'd start by seeing what experienced people thought here / ask silly questions here before asking them elsewhere.
    Cheers folks.
  2. The Following User Says Thank You to Risky For This Useful Post:
    MB (12th February 2021)
    330 Post(s)
    Hi mate, yes i would consider adding a Lift pump toyour setup. You do not have one from factory. The Fuel pump creates vacuum and sucks out from the back tank to the back of the pump, adding a further restriction just ades to the Starvation. adding some positive pressure to the back of the pump will be rewarding.
  5. The Following 3 Users Say Thank You to MudRunnerTD For This Useful Post:
    MB (12th February 2021), mudski (12th February 2021), Risky (12th February 2021)
  6. #3
    475 Post(s)
    I nuffy second MRTD’s kind guidance there, especially if looking to tackle some steeper ongoing mountain tracks.
    Fuel delivery wise when ‘climbing’, imagine how hard our poor old highway level built injection pumps are working their arses off when the pickup point is some 0.5m below the now ‘climbing’ level line if that makes sense.
    Once did properly starve my 6.5L Chev NA through a GU donor system as their injection pump is even higher again way up top on the front of the big V front end
    Instant air sucking power injection somehow experienced I assume and a full out of control climbing wheel traction loss had me stuck on a ledge with a potential broken valve spring
  7. The Following User Says Thank You to MB For This Useful Post:
    Risky (15th February 2021)
  8. #4
    Just make sure you have spare filters on board. I know those filters your mechanic will use, and they are not something thats easily available if you are out in the middle of shit creek with a blocked filter. Also another concern is the flow rate. while it will be good with a stock TD42, having two fuel filters inline will create flow issues with a modified TD, even a modified ZD.
  9. The Following 2 Users Say Thank You to mudski For This Useful Post:
    MB (12th February 2021), Risky (15th February 2021)
  10. #5
    109 Post(s)
    Not having a go, and might learn something here myself, but why would you need a pre filter in a TD42?
  11. #6
    The only reason I think, is if you live in a remote area where fuel supply is less than desirable.
  12. The Following User Says Thank You to mudski For This Useful Post:
    MudRunnerTD (12th February 2021)
  13. #7
    330 Post(s)
    ^^^^^^^ what he said ^^^^^^^^
    Really they are beneficial to catch water in fuel and other contamination found in crap tanks. Even the onboard tank.
  14. #8
    109 Post(s)
    Umm yeah, but the standard fuel filter has a water bowl and drain valve at the bottom, so why do you need another to complicate things?
  15. #9
    To answer your question, you don't.
  16. #10
    109 Post(s)
    That's why I asked the question.
