Page 989 of 1054 FirstFirst ... 4898899399799879889899909919991039 ... LastLast
Results 9,881 to 9,890 of 10538
  1. #9881
    We have been waiting a while for our schedules to coincide with our builder's and finally happening. Going to be an epic extension to the house bringing outdoors inside.
  2. The Following 2 Users Say Thank You to Winnie For This Useful Post:
    MB (8th February 2021), rusty_nail (8th February 2021)
    475 Post(s)
    Second thoughts, if that is your kitchen window remembered from a kind shindig youz once had?
    Happy to rough slab you two Winnie’s up some ironbark for a servery connection between his & hers worlds possibly?
    The eatery full open louvrey window might blow your budget but worth seeing what ‘Stegbar’ could quote up for the builders plug and play install whilst there working
    Winnie (8th February 2021)
  6. #9883
    Mate that is exactly our plan, a little later down the track though. Big bifold window between the kitchen and deck with a milled wood bench underneath.
  7. The Following User Says Thank You to Winnie For This Useful Post:
  8. #9884
    Well done mate, that looks bloody brilliant. Good to see you getting into it!!
  9. The Following User Says Thank You to rusty_nail For This Useful Post:
  10. #9885
    475 Post(s)
    FWIW: Finally swapped the GU’s 35’s across to the little GQ now with 40mm reduced rear guard butchering I had done earlier:
    Externally it still looks tight highway old height and pre 2” mild lift work but trying my best to keep it looking OEM tame as best as possible
    Radius arms forward shifting castor correction work thankfully starts next week with extended bump stops holding up 3” down travel shocks so fingers crossed I won’t hear that dreaded full lock downhill ‘dickada dickada dickada’ crap
  11. The Following 2 Users Say Thank You to MB For This Useful Post:
    AB (9th February 2021), Rossco (9th February 2021)
  12. #9886
    May 2016
    lower west victoria
    30 Post(s)
    GQ high mount gardening
    you don't look bogged there mate, are you going up hill??????
  13. The Following 6 Users Say Thank You to 10G For This Useful Post:
    MB (10th February 2021), mudnut (9th February 2021), Plasnart (9th February 2021), Rossco (9th February 2021), rusty_nail (9th February 2021), TPC (9th February 2021)
  14. #9887
    193 Post(s)
    It's pretty wild in the back blocks of ye olde Moe, definatly need your witts about ya . . .
  15. The Following User Says Thank You to Rossco For This Useful Post:
  16. #9888
    May 2016
    lower west victoria
    30 Post(s)
    maybe drop ya tyre pressures winnie???
  17. The Following User Says Thank You to 10G For This Useful Post:
  18. #9889
    475 Post(s)
    Took a bit of a gamble yesterday purchasing a D31A for the GQ’s main battery as I’ve only ever been able to fit slightly smaller D27’s in GU’s main trays length/width wise previously believed.
    Thankfully it did fit last night tested with only a slight position twist required which was made possible by the offset spiral core design:
    Next overlooked problems found were the D31A terminal posts are all mounted central unlike the D27 variants with standard off-sets & the taller battery height brought the terminals too close for comfort to the closed steel bonnet heat lining.
    Problem easily solved thanks to ‘Baxters’ passing through there today:
    ‘Unilug’ is a brilliant Aussie design just found and are so happy I don’t have to modify the OEM engine wires longer to reach too
  19. The Following 6 Users Say Thank You to MB For This Useful Post:
    Cremulator (11th February 2021), jay see (10th February 2021), mudnut (10th February 2021), MudRunnerTD (15th February 2021), mudski (10th February 2021), rusty_nail (10th February 2021)
  20. #9890
    Wow! I like those Unilugs.
  21. The Following 2 Users Say Thank You to mudski For This Useful Post:
    MB (10th February 2021), MudRunnerTD (15th February 2021)
