Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: TD42 Overcooling
    465 Post(s)
    Apologies Brother Mark, much like the McTrol.com.au Photograph Rulings, Numbers pretty please or it never dever happened Legend
    Bit hard to take a photo whilst driving.
    MB (5th January 2021)
    465 Post(s)
    The real test my friend is on Friday towing the camper to Omeo. I’m optimistic mate.
  5. The Following 3 Users Say Thank You to mudski For This Useful Post:
    MB (5th January 2021), Rossco (6th January 2021), Winnie (6th January 2021)
  6. #13
    475 Post(s)
    Which Thermostat you running these days Old Mate?
  7. #14
    465 Post(s)
    Latest purchase was the Dayco DT79A. 82c opening temp, spaced out the bypass as per interwebs advice. Made F.A difference, went back to the Tridon Hi Lfow 78c stat, which was removed to fit the DT79A. Slightly better with the Tridon, ever so, than the Dayco...
    MB (7th January 2021)
  9. #15
    193 Post(s)
    Last climb coming up there will give it good test lol .
  10. The Following User Says Thank You to Rossco For This Useful Post:
  11. #16
    465 Post(s)
    Yeah it’s been a while since I been there. I know it’s hilly so it will be a good test. Just looking forward to chilling out more that anything.
  12. The Following 2 Users Say Thank You to mudski For This Useful Post:
    MB (7th January 2021), Rossco (7th January 2021)
  13. #17
    475 Post(s)
    I’m surprised you haven’t trialled the OEM 82C as of yet mate, it was your helpful findings of the part number back in 2019
    mudski (10th January 2021)
  15. #18
    Aug 2011
    River Heads Q
    4 Post(s)
    Quote Originally Posted by leroy123 View Post
    Im pretty happy that the gauge is reading right.
    I forgot to look back at that old thread recently, i have tried most suggestions on there now and the problem is still there.
    I did run it yesterday without the top rad hose on, when cold there was a small amount of water flowing out which must be coming thru the jiggle pin hole.
    I might braze the hole for the jiggle pin closed, will this cause any problems? is it there to assist with removing air from the block side while cold?
    Otherwise the last thing i can think of is change back to stock injectors?
    I have a VDO temp gauge and it took 3 to get it right. The first one had readings too high and then low issues like yours. The second one just kept going up and not stopping until it went off the dial. The third one appears to be right and goes up and down in different conditions.
  16. The Following User Says Thank You to Wizard52 For This Useful Post:
    MB (9th January 2021)
  17. #19
    465 Post(s)
    I put the Dayco DT79a in. Same stat but with the longer bypass. Did FA.
  18. The Following User Says Thank You to mudski For This Useful Post:
    MB (11th January 2021)
  19. #20
    475 Post(s)
    Bugger Mate!
    So you’re still overcooling down hills? I seem to recall yours getting as low as 46C cruising downwards over winter where mine was also getting as low as 56C but all good now.
