Results 31 to 36 of 36
Thread: TD42 T Gets real hot but only when towing
  1. #31
    Expert JackoGQYoot's Avatar
    Oct 2017
    WA
    Hi guys
    Is it normal for my factory temp gauge to read at about 1/4 - 1/3 all the time? Is this where the gauge should sit? The gauge also takes ages to come up after I start the engine. Any suggestions?
    chrz
    Td42 coily
    Quote Originally Posted by JackoGQYoot View Post
    Hi guys
    chrz
    It's normal for the TD42 to take a while to get to operating temperature.
    1/4 to 1/3 is really good. That's where mine sits unless under load on a really hot day it can creep just past half way.
  4. #33
    193 Post(s)
    Yeah same, mine sits about there and is good & normal. Doesn't take to long to get warm, probably 5 mins is up to temp.
  5. #34
    583 Post(s)
    How long is a while?
    Cold start up they can take for ever and a cold engine running is where most engine wear occurs.
    If your concerned then check the thermostat is not stuck open.
    I personally don't idle my car to get to operating temp as it would take upwards of 5 mins.
    You want your engine to reach operating temp sooner rather than later without putting stress on it of course.
    If you live on a hill going downhill to town then a huge win, idle for a minute or so and cruise down hill or after a minute idling use the throttle control up a little bit to say 1000rpm to reach temp quicker without load.
    Edit: quoted Winnie by accident lol
  6. #35
    I could drive 15 minutes in mine until it gets to operating temp of circa 80c. This is with a cool but not cold morning and just driving around suburban streets. Cold mornings, below 10c forget it. If I get onto the freeway it will warm up much quicker. Leaving it idle it I would run out of fuel before it reaches temp. Lol.
  7. #36
    Jul 2018
    Quote Originally Posted by Dark 1 View Post
    Second that.
    I can confirm this to, 5th gear - you'll get hot. 4th gear is perfect on any (even slight) load. When going along the flat or down hill, I'll knock it into 5th.
    I find, if egt hits 450 -500, start backing off then - if you want your temp gauge to stay under halfway..
