Results 1 to 10 of 20
Thread: TD42 Overcooling
    Aug 2019
    TD42 Overcooling
    Hi,
    I have a 91 GQ Nissan Safari. I am having issues with it not getting upto temp and then when pushed will overheat.
    About the truck:
    Aftermarket Kinugawa TD05 water cooled
    top mount inter cooler
    custom air manifold, air box, 4" snorkel
    4" straight thru exhaust
    Things I have tried:
    New radiator
    New nissan rad cap 1.1 bar
    new nissan water pump
    new nissan thermostat. Tried a tridon 82 deg, tried a 88 deg nissan one for a terrano, tried a aftermarket modified one with a longer bottom section to block the re-circulation better (from Trundles automotive in NZ)
    re oil fan hub
    new fan blade
    has shrouds around radiator
    I only had the truck for 1 month before I removed the entire front plate due to a small water leak by the injector pump at the same time I removed the head and did the turbo ect. so I don't know if the issue was already there or not.
    I didn't actually remove the injector pump from the front plate as I didn't want to play with the timing.
    All new nissan seals, head bolts ect.
    I think the overcooling can only be caused by a faulty thermostat? what other things could cause this?
    I have also put reco higher crack pressure injectors which I did read somewhere could affect the temps?
    Just went on a camping trip with the trailer about 4500kg GCM and it did sit at about 82 deg consistently but would sometimes drop right down to 40 deg when on level road and any hill would see the temps rise, never went above 100 deg but the hills weren't that big. Pyro was sitting on 350 ish and upto 500 max on hills (100mm after turbo in dump pipe)
    unloaded it struggles to get above 60 deg unless going up long hills where it will go up to 100 so I stop and turn around it drops to 40deg rapidly.
    Just went for a run without the thermostat in and wouldn't go above 60deg up a long hill and when heading back down temps dropped slowly at a steady pace.
    This makes me think the rad and most other bits are working but the coolant must be bypassing the thermostat somehow?
    Is there only one type of water pump that will fit this motor?
    I have also noticed that the rad hoses don’t seem very firm when the truck is running. Should the only be hard when at operating temp?
    No water in oil or bubbles in overflow and water level doesn’t drop over time.
    Sorry for the long post but better to get all the info on the from the start.
    20210103_131418_30.jpg20210103_131433_30.jpg20210103_131500_30.jpg20210103_131509_30.jpg
    195 Post(s)
    Sounds like you have a problem a few on here would envy!
    49 Post(s)
    Just thinking out loud here.
    Could there be an issue with your gauge, sender or wiring.
  5. The Following User Says Thank You to jay see For This Useful Post:
    mudski (5th January 2021)
    475 Post(s)
    G’day again Leroy Mate!
    Might be best to keep on track in your original thread brother:
    https://r.tapatalk.com/shareLink?sha...7&share_type=t
    It still wreaks to me of too much water flow by way of thermostat, it doesn’t take much to achieve the lower temperatures you describe and 100C in a TD42 is not overheating IMHO.
    Aug 2019
    Im pretty happy that the gauge is reading right.
    I forgot to look back at that old thread recently, i have tried most suggestions on there now and the problem is still there.
    I did run it yesterday without the top rad hose on, when cold there was a small amount of water flowing out which must be coming thru the jiggle pin hole.
    I might braze the hole for the jiggle pin closed, will this cause any problems? is it there to assist with removing air from the block side while cold?
    Otherwise the last thing i can think of is change back to stock injectors?
    475 Post(s)
    You’ll see in the other thread mate that the missing jiggle pin on the OEM Tropical 76.5C was found to be my colder climate low temperature issue. As soon as I changed to the OEM 88C with jiggle pin included the issue disappeared immediately. I guesstimated at cold idle the jiggle pin-less thermostat was still letting through up to a litre or so per minute idling.
    With the OEM 88C out of a TD27 it now runs year round in Southern Victoria between say 86C idle up to say 93C highway and a max of 99C hot summer towing.
    Best highway fuel economy was found at 92C and this was confirmed by one of our TD42 experts on here as their “Sweet Spot”
    If you feel the 88C setting is too high for your needs the OEM 82C also comes including a jiggle pin
    465 Post(s)
    Yeah sounds odd that the water temps will drop that low. The old TD is a cast iron block, once they get hot the block gets nice and warm and will usually stay warm to an extent.
    I'd be checking the gauge first. Cheaper than swapping out injectors.
    Bit of an update with my TD and the injectors. I had mine reset to factory spec as I was convinced this was the cause of my issues, it did squat. Made it slightly worse if anything. I then spoke with the pump builder, who also originally at the time build the injectors aswell. According to his data, the pump he built for me, the injectors required are high crack pressure injectors, 150bar high. So I took them into him, he reset them to his spec, and my temps seem more stable now, still gets up there a bit bit I haven't had the chance yet to really test it out.
    MB (5th January 2021)
  11. #8
    475 Post(s)
    “More stable” come on Mr Mark Mate, real world numbers or it never happened
  12. The Following User Says Thank You to MB For This Useful Post:
    Rossco (5th January 2021)
  13. #9
    465 Post(s)
    Haha. Ok. Took it for a blast down East Link. Ambient temps circa 20c, car empty, 100kph temps eventually got to 90c, unladen. Took a while but once the block had some time to soak in the heat it stayed there. Until I hit an incline. lol.
    Before It would act the same but get there earlier. I still need to get the pump timing done. Haven't had a chance with this yet.
  14. The Following User Says Thank You to mudski For This Useful Post:
  15. #10
    475 Post(s)
    .....Until I hit an incline. lol.
    Apologies Brother Mark, much like the McTrol.com.au Photograph Rulings, Numbers pretty please or it never dever happened Legend
