Results 1 to 9 of 9
Thread: GQ Patrol TD42 (Brakes)
    Nov 2020
    Brisbane qld
    Hey guys i got a gq td42 with a hard brake pedal
    Ive replaced the following items
    Multiple Brake boosters
    All new vaccume hoses
    Bled brakes incase
    New vaccum pump
    Regreased caliper slides
    Has one way valves installed
    You get about 2 sometimes 3 presses on the brakes then they go rock hard the clutch also goes hard.
    Took my car for a underbody was today and felt my clutch getting funny as i was in there then i come out i had rock hard brakes that didnt want to stop im really lost on what to do has anyone got any ideas for me please
    Expert Deano2506's Avatar
    Apr 2017
    Hobart,tasmania
    Sounds like it has to be a vacuum leak somewhere.
    So they're good for 1st 2 or 3 pumps ???
    Leak in vacuum tank maybe?
    You could disconnect at alternator or vacuum pump(depending on model),seal it Then put some compressed air in the system and listen for where the leak is.
  4. The Following User Says Thank You to Deano2506 For This Useful Post:
    MB (4th November 2020)
    475 Post(s)
    Youtubey copy test I once trialled, seems to work
    https://youtu.be/kpZwpkyhqyg
    Patrol Guru 0-TJ-0's Avatar
    Jan 2017
    South Australia
    11 Post(s)
    Quote Originally Posted by Hilly94 View Post
    Bled brakes incase
    New vaccum pump
    Stupid question, but I assume the car is running when you're testing the pedal? You'll never stop it going hard if the car is off.
    Definitely vacuum related.
  7. The Following User Says Thank You to 0-TJ-0 For This Useful Post:
    MudRunnerTD (5th November 2020)
  8. #5
    Jan 2017
    South Australia
    11 Post(s)
    Do the pedals go hard if you leave the car sit? As in, when you get in the car in the morning and go for that first clutch press before you start the engine is the pedal always hard?
  9. #6
    330 Post(s)
    Vacuum Leak for sure mate. If it affecting your Brakes and Clutch then 100% Vac leak. I had a split tube across the fire wall.
    You have replaced the vac pump on the back of the alternator so I would be checking all the Vac lines and also the Vac canister.
  10. #7
    Nov 2020
    Brisbane qld
    Cheers everyone appreciate the feed back took the car to Stop masters brendale today to get a diagnosis and it is leaking vaccum from the clutch booster
  11. The Following 7 Users Say Thank You to Hilly94 For This Useful Post:
    0-TJ-0 (6th November 2020), Bidja (6th November 2020), Cuppa (6th November 2020), MB (6th November 2020), MudRunnerTD (6th November 2020), mudski (6th November 2020), PeeBee (6th November 2020)
  12. #8
    I should have picked that up in your first post with the list of things you had replaced. I used to sell ship loads of clutch booster repair kits for the GQ's when I had my shop. Good to see you have found the issue.
  13. #9
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    37 Post(s)
    Terrific that you came back advising us of the fix. Good to share the joy and all learn from result.
    So many do not bother closing the loop _well done.
  14. The Following 4 Users Say Thank You to Bidja For This Useful Post:
    0-TJ-0 (6th November 2020), Cuppa (6th November 2020), MB (6th November 2020), MudRunnerTD (6th November 2020)
