13th May 2011, 12:11 PM
Xforce Exhaust Systems
Xforce has an extensive range of mufflers, tips, cats, & resonator to suit any vehicles that already doesn’t have a bolt on option. Its Mufflers are made from 304 grade stainless steel with a straight through design and dual layer packing, consisting of stainless steel mesh and fiber glass, this ensure maximum sound silencing effect and hi-temperature resistance while maximizing flow and performance.
Xforce’s R&D team put its mufflers and exhaust systems through numerous in-house dyno testing and road tests to ensure the best performance output and drivability is obtained.
Some example of what Xforce has to offer and for the full range of universal mufflers check out the link: http://www.xforce.com.au/products.ph...ersal_mufflers
Cannon Muffler
Features:
304 grade stainless steel material, highly polished, mirror finish;
Straight-through internal tube design with perforated holes,ensure minimum restriction;
Duo layer packing, stainless steel mesh and fiber glass, ensure maximum sound silencing effect and hi-temperature resistance.
Parts:
5” Barrel Cannon: LE05,LE05L,LE06;
6” Barrel Cannon: SB03,SB05,LP02,SV01
7” Barrel Cannon: SV02
Muffler Hanger Clamp: Muffler hanger can be weld onto this clamp, prevent damage to the muffler canister;
Adjustable Silencer: Can be directly installed into most of the XFORCE cannon style muffler to adjust sound volume. Fit 3.5”, 4” and 4.5” O.D Tip
Oval Muffler
Features:
Straight-through internal tube design with perforated holes;
Parts:
5”X8” Oval: P-EX10, P-EX11, P-EX12
6”X9” Oval: PT01, PT02, PT06
6”X10” Oval: MP01, MP02
Twin Loop Muffler
Twin Loop Style Muffler design features exhaust gas flowing twice through muffler canister before exit, thereby doubling the silence effect while maintaining minimum restriction.
Parts:
7” Round Twin-loop: S10
5”X8” Oval Twin loop: S12
Resonator
Resonator including two types:
Hot-dog Style: 3.5",4",4.5" O.D;
Oval Stlye:4"X8", 5"X8", 4"X10"
13th May 2011 12:11 PM
