18th September 2020, 10:54 PM
TB42 Nikki Carby Settings
Hi All,
Currently rebuilding the carby and the settings in the Gregory's manual for the primary slow jet are 0.54mm, what is this in reference to. Is it screwing the jet all the way down to the bottom of the port and then unscrewing it 0.54mm or am I completely wrong and it means something totally different. All the jets have different settings in mm but no explanation of what that measurement is in reference to, any help would be greatly appreciated.
18th September 2020 10:54 PM
18th September 2020, 11:29 PM
it is the diameter of the hole in the middle of the jet
19th September 2020, 11:46 AM
Thanks for the response Bigcol, now that you say that I am kicking myself for asking such a stupid question. I guess what I really need to know is that the jets are threaded and screw in and out so when refitting them what depth do I screw them back in. Do I screw them all the way down or is there a specific depth that each jet has, reason I ask is because the manual I have says it is important that the jets are installed to the correct position on assembly. This may just mean don't mix them up but I want to be sure so I don't need to pull it apart again.
19th September 2020, 05:27 PM
MickMc
I'm not a mechanic but I've replaced a few jets.. Normally they just screw in until they stop. Make sure you've got the right jet for the right hole.
20th September 2020, 11:14 AM
MickMc
Thanks for the response Bigcol, now that you say that I am kicking myself for asking such a stupid question..
no such thing as a stupid question
not everyone knows everything
yes, they need to be screwed home securely - tight - all the way
