Page 956 of 1056 FirstFirst ... 4568569069469549559569579589661006 ... LastLast
Results 9,551 to 9,560 of 10551
  1. #9551
    Advanced Dasa's Avatar
    Aug 2019
    North central VIC
    While the rad was drained I took it out to blow out crap from the fins and scrape off the mud wasp nests only to notice the end tanks were rating with all the metal flakes that had accumulated in them during the flush.
    With a bit of flushing while shaking I think the rad is finally coming clean but there is probably more in the hoses, block and heatercore yet.
  2. The Following 2 Users Say Thank You to Dasa For This Useful Post:
    10G (6th August 2020), MB (9th August 2020)
    May 2016
    lower west victoria
    30 Post(s)
    Whoa, chunky. It makes you feel good though when you see crap like that come out, makes you feel like the work you've done has been worthwhile. That's how I feel anyway.
  5. #9553
    Aug 2019
    North central VIC
    Yeah if only the work was over I just pulled the thermostat to try give the block a better flush and thankfully the bolts didn't snap but the thread from the housing came with the short bolt and the long one feels like it is going to snap if I put it back in.
    Might see if it can toodle 15k into town with one bolt holding and have the local engineering shop re-thread it.
    Otherwise I see if the housing comes off the block any easier.
  6. #9554
    80 Post(s)
    The chunkier stuff can block the water galleries, especially the small holes in the head gasket.
  7. #9555
    Expert Mickhead's Avatar
    Oct 2019
    Tested some stuff on the poo. Ok. The 02 zd30 is a bit hard to start first thing on a Freezing cold melbourne morning. Probably 10 revolutions maybe 3 to 4 seconds.. Fires up, runs rough for another second or two. Then runs beaut. Lets out a puff of white vapour. Starts fine all day after that. Put a DC current clamp on the fat wire going to the glow plugs. Relay clicked, but no current drawn. Tested clamp meter on another source and it works. So.. GPs are not working. Do I fix them or let sleeping dogs lie?
  8. #9556
    With all the spare time with our lock down I parked the patrol on Wednesday night after work and did absolutely sweet f@#k all to it. So much so that I'm driving the Clubsport tomorrow. Give it a good 5 day break.
  9. #9557
    475 Post(s)
    Politely pulled over up our big little hill on the way home from the supermarket in the old GQ ute with some 750kg atop to let a V8 Landcrab wagoon arrogantly blast by.
    I swear they are a different breed these days, even hardwood logging trucks usually thank me :-)
  10. The Following 5 Users Say Thank You to MB For This Useful Post:
    Avo (11th August 2020), Cremulator (11th August 2020), Rossco (11th August 2020), rusty_nail (11th August 2020), Yeti's Beast (1st September 2020)
  11. #9558
    Quote Originally Posted by Dasa View Post
    Did you get to the big in the block when you drained it,it is on the left hand side between cylinder 5 and 6 I think from memory,when I did ours I flushed it a few times...
  12. #9559
    I would have waved at ya mate....even in a lazycrab
  13. The Following User Says Thank You to Avo For This Useful Post:
    MB (11th August 2020)
  14. #9560
    475 Post(s)
    Thanks Brother, even just a quick left/right/left...Tittie flash would suffice a betterer days end :-)
