13th July 2020, 10:22 PM
#351
Time consuming day today. Managed to get the 4 fuse blocks mounted in the vehicle and run the pos/neg cables for the deep cycle side of things. Tomorrow is the ign source cables - this is going to be a struggle as there are more cables and I think quite a few will require extending. Also have 3 cables that I somehow didn't label and one joined with a crimp connection came apart and I can't locate the other end - always happens. 7 hrs is about the limit for me screwed up like a wet towel, so will see how it lands tomorrow, but it looks a hell of a lot better.
The Following 4 Users Say Thank You to PeeBee For This Useful Post:
MB (14th July 2020), mudnut (13th July 2020), MudRunnerTD (22nd July 2020), mudski (14th July 2020)
13th July 2020 10:22 PM
14th July 2020, 05:19 PM
#352
Rewire complete - 3 wires to chase down but they should show up pretty easily when something doesn't work. Only issue was the actual fit of the blade fuses, couple were out of alignment and took a bit of joggling to fit the fuse. They were cheap in all honesty, however could not find a Blue Seas quality fuse block with 12 slotsfuses.JPG with the LEDs. Still pretty busy though.
The Following 2 Users Say Thank You to PeeBee For This Useful Post:
0-TJ-0 (14th July 2020), MudRunnerTD (22nd July 2020)
14th July 2020, 05:50 PM
#353
What a champion That is one can of worms dealt with.
The Following User Says Thank You to mudnut For This Useful Post:
14th July 2020, 05:52 PM
#354
PeeBee
Not entirely sure as was sort of sucking in a lot of info at the one time. I think at 100kph I am doing around the 1900-1950rpm, 110kph sits around 2000 - 2050maybe, not sure on 120kph. When i am next out I will take some better numbers. These are probably worst case in some regards as the sample time is so short. Also, I have a large frontal area with the roofrack that does not help. Yes 33's and 3,9 with man box.
I looked at my spreadsheet and with those tires and diff ratio, you should be doing 97km/h at 2000rpm, 120 reads 2500rpm.
would be interested if the spreadsheet is accurate.
The Following User Says Thank You to poindexter For This Useful Post:
14th July 2020, 06:12 PM
#355
Thanks ralph, I will take a closer look next time. My speedo is out as the conversion was done with 32" tyres, and by the GPS 1 am 5klm/hr out. I am a bit doubtful about the speed as the rolling dia is a bit pressure dependent anyway.
14th July 2020, 06:24 PM
#356
mudnut
Yep, it was a dogs breakfast for sure, now a bit more organised and one circuit per fuse.
22nd July 2020, 06:30 PM
#357
Went chasing the home for the 3 extra wires, started by seeing what wasn't working - bugger me there are 5 things not working and 3 wires - just as well we are in lockdown or this would be a real drag
22nd July 2020, 07:05 PM
#358
Moderator
PeeBee
Just.....Bloody Hell mate!! Proud of your efforts there. I have lived that dream on a smaller scale and that is a great effort. I hate those OCD Auto Elecs that make it look like Art. FFS there is so much going on you have to pack it in. You should be very pleased with that effort mate. My GQ Centre Console is awesome but behind the scenes looks messy but it works, its safe and its fused. Stuff the Haters. Great effort mate.
Still Scary as Faarrrkkk. But i remember the first time i saw your rig OMFG! you burned a hole in my brain. This is a huge move forward mate. Well done.
![Cool](images/smilies/cool.png)
Check out my Toy -->
Rogue Dung Beetle
22nd July 2020, 07:08 PM
#359
Moderator
and on the bright side..... If it does catch fire at least your feet will be warm.....
Rogue Dung Beetle
22nd July 2020, 07:11 PM
#360
Moderator
I want to see the fuse box cover with the sticker on it that says which fuse does what??
i use an Ap on my phone for lists, this would be a great spot to keep a fuse list like that! that is Epic mate.
Rogue Dung Beetle
