Results 1 to 5 of 5
Thread: ABS warning lights stuck on after using rear diff locker and driving off-road
    Beginner denk82's Avatar
    Nov 2017
    SE QLD
    Hi guys. Ive searched the forum and thought Id post my issue (latest issue!!). Was off-road last weekend doing some easy to easy/moderate tracks and I used my rear locker a few times and noticed late in the day after using it, my ABS lights are on and not turning off. Ive checked the ABS connections on all the wheels and appear fine. There was some slight debris/twigs near the sensor on the back of the brake rotor but there was not a lot at all and just brushed away.
    Brakes feel fine when braking, fluid levels are ok.
    Where else should I be looking?
    Check your trailer plug and loom for damage (if you have one)
    Check your brake lights for illumination.
    Check your fuse panel for blown fuses (esp any to do with ABS, Brakes, etc).
    Does the cruise control still work?
    Nov 2017
    SE QLD
    Yeah i have brake lights, plug seems ok and loom. No blown fuses and yeah cruise control is working fine.
    Expert altech's Avatar
    Nov 2011
    Rupanyup, 3388, VIC
    Maybe disconnected the battery for 10 mins or more , it might reset it all
    97 GU Ti 4.5 on lpg , uhf icom Pro400, Garmin GPS Maps, HD-Lukas Dash Cam with gps tracking. Snorkel , I-Max 12000lb Winch , Twin rear light bracket on wheel carrier for light & uhf antenna,Draws unit, Electric Cargo barrier, HID headlights kit, LED Light Bar, 2 inch lift with HD King springs and Monroe Gas Magnum TDT 4WD Shock Absorbers, BS Dueler 697 Lt 285/75R-16 .
  5. #5
    Nov 2017
    SE QLD
    Quote Originally Posted by altech View Post
    Tried that straight away but nothing... however... after a detailed inspection underneath i inspected all sensor wires and found the rear left cut clean through which i didnt notice the first time underneath. id say a stick got caught up on the drive out bush and just got lodged in the exact spot that hit the wire and cut it. just picked up a new one from a wrecker for $50.
