Results 11 to 20 of 37
Thread: GU front end clunk
    465 Post(s)
    Quote Originally Posted by Peggy View Post
    Yeah mate it’s only under load if I let off or put the clutch in it goes away, will test the one locked in at a time cheers
    Remove the Hub and see if the gears that mesh together when you lock the hubs are not slipping. This was the issue with the Chinee hubs I had. I could clearly see the wear marks from the teeth jumping.
    Mar 2020
    So I tested it out and it only does it when both hubs are locked in, had the hubs off the other day couldn’t see anything to wrong with them, they hard a fair bit of play but I assumed that was normal but could be wrong
  4. #13
    Mar 2020
    And if I’m accelerating hardish if I’m just cruising it’s fine
  5. #14
    Mar 2020
    And they are marked AVM made in Brazil so assume they are legit
  6. #15
    465 Post(s)
    Have you got any other hubs you can access to swap over to try. Just thinking unless you have a front locker one hub open wont work as a test.
  7. #16
    Mar 2020
    Nah mate might just bite the bullet and buy some new ones, sick of the stupid torx heads on the AVM ones anyway haha and if that doesn’t fix it I’ll pull the diff out
  8. #17
    174 Post(s)
    Hey it’s definitely drive line related as it in crease and decreases with speed, changes the unis no change but I tested and it only happens when the hubs are actually locked in should have done that first I know haha, they are AVM HD free wheeling my next question do they require the “egg ring” if so there is none which could be causing the issue
    I guess if you know there is no egg ring you've had the hubs apart ...... so did the clunking start before or after you had them apart. My car had no egg rings in it when I got it (standard manual hubs) & I was strongly advised to put them in, which I did. Without them there is room for movement, which may or may not be causing your clunk. It didn't in mine, biut I think I was just lucky & that it was only a matter of time before a problem arose. If I were you I'd buy some & fit them. Won't be a huge expense & it may fix your problem. Even if it doesn't you'll have had a good look at your hubs & know they are not a problem waiting to happen.
    Ah just read you've had them apart & have some play in them .... it's possible the egg rings will take up the play.
  9. #18
    465 Post(s)
    He’s running AVM hubs mate. They don’t use the egg ring.
  10. #19
    174 Post(s)
    Aha, that's probably why he said they were missing then.
    I always thought they were pretty much a straight copy of the OE hubs.
  11. The Following User Says Thank You to Cuppa For This Useful Post:
    mudski (8th June 2020)
  12. #20
    465 Post(s)
    They are a two piece design. Full auto hubs converted to manual are better than AVM hubs.
