1st June 2020, 10:58 AM
Hey mate no under no load just instant loss of power no mods that I know of.
Apparently had full engine rebuild in 2019, set of pistons and rings, conrod bearings, head gasket, set of injectors, new sump, new clutch.
It’s a manual and struggles through all the gears, if u keep the boot down in any gear once it gets over 4000 rpm the engine management light comes on, I have a boost gauge and it gradually gets up to 15 psi.
1st June 2020 10:58 AM
1st June 2020, 02:02 PM
So if its instant, like the motor is trying to shut down, it sounds like limp mode. These motors are real picky with over boost. Is the intercooler original? Crimped ends on the core, or welded? If they are crimped, even if its not, remove the intercooler and check it for oil spots, particularly on the underside. If it is, the Intercooler is leaking boost. Leaking boost you will lose a fair bit of power. Look at this and report back.
1st June 2020, 05:20 PM
I'm thinking over boost & limp mode.
Get a cheap OBD scanner & the Torque app for your phone and check your boost, that's a cheap convenient way to get a second 'boost' opinion.
1st June 2020, 09:33 PM
10G
Those scanners wont work with the Di motors. ECU talk is the only option. What worked for me on my old Di to overcome the overboost limp mode nightmare was to buy the HPD billet high flow MAF housing. I went from 16psi on the dot hitting limp mode to going to 3 plus psi boost and still no limp mode. Wasn't cheap but I no longer had limp mode issues. I really don't miss the ZD to be honest....
1st June 2020, 09:39 PM
Oh come now @mudski - it’s the ZD30 that 1st brought us together so there’s some good in em 🤣
1st June 2020, 09:45 PM
Sprock
Oh come now @
mudski - it’s the ZD30 that 1st brought us together so there’s som egos in em 🤣
Yeah true. If it wasn't for the ZD''dirty" I would never have met you!!
2nd June 2020, 10:04 AM
#17
See mate there’s a positive in everything
The Following 2 Users Say Thank You to Sprock For This Useful Post:
mudski (2nd June 2020), Rossco (2nd June 2020)
2nd June 2020, 10:05 AM
#18
So going by your response - meeting me was a good thing - or I would’ve got a ‘yeah dammit’ response haha
2nd June 2020, 10:27 AM
#19
I’m with Mudski, check the intercooler - if it’s an original crimped end style 99.9% chance it’s stuffed , get a welded end type , I got mine off eBay & wasn’t that pricey & still goin strong , also put a piece of clear hose from the filter outlet to the injector pump & check for air bubbles in the fuel . ANY bubbles will cause you grief .
The Following User Says Thank You to Sprock For This Useful Post:
2nd June 2020, 02:13 PM
#20
Sprock
Ohh I think we'll just leave it at that? Haha!
