26th May 2020, 09:47 AM
Engine Quitting in 2nd Gear
Hi all
New to the Patrol family, bought an ex-telstra 2012 single cab GU a month ago. No huge mods so far but experiencing a re-occuring issue with the engine shutting off whilst driving.
It's happened 5 times now in the last month and its always the same circumstances. First drive of the day (not necessarily cold engine) within a few minutes under moderate acceleration in 2nd gear the engine shuts off, no warning lights. First attempt to crank back over and no firing, second attempt always starts it. All 5 times it happened exactly like this.
I had John at Turbo-Glide in Woonona check her over when I first got her, checked injector pressures, put her on the dyno and fitted a Berrima Diesel DP chip I got for her and he was happy with how she was performing. It was throwing a fuel code so we replaced the suction control valve and after doing some reading here I also replaced the ECM relay with a new one. Still having the same issue as before.
Thanks for the wisdom in advance!
Dave
26th May 2020 09:47 AM
26th May 2020, 11:39 AM
Welcome to the forum. You might need to reset the ECU, but I'm no diesel guru. Please head over to the introductions thread and you might get a better response to your questions.
26th May 2020, 02:01 PM
First thing I'd do is remove the chip, reset the ECU by disconnecting the battery for half hour and try again.
