14th April 2020, 09:58 AM
#11
jff45 thanks for your post. It has become very confusing. After reading your reply I decided to rechecked for the umteenth time the old TPS with a multi meter. It has now found life again after about a week of death. I reinstalled it on a temporary basis into the Patrol and tested it with the ECU Talk. Again it showed life, although the readings are down compared to the new one. I'll change it back again and start looking further under the bonnet.
14th April 2020 09:58 AM
29th April 2020, 09:07 AM
#12
Found the problem. It was the small switch screwed closest to the accelerator arm and has the wiring terminal above the TPS. I checked the resistance and found it to be faulty. Unfortunately the switch isn't sold separately in Australia and had to buy a complete accelerator assembly.
Thanks to the fellas who had input.
29th April 2020, 06:51 PM
#13
Homebrew
Nooooo I have one of those switches here!!!! You coulda had it for the cost of post!
1st May 2020, 08:24 PM
#14
Found it!
1st May 2020, 09:04 PM
#15
Patrol Guru
You’ve got very masculine looking hands Mudski 😉
The Following User Says Thank You to Sprock For This Useful Post:
6th May 2020, 07:59 PM
#16
Sprock
Got I gotta stop drinking whiskey while in the garage. I forget I’ve done things in here. Lol I forgot that I found this part, totally...
Too late. I’m in here now, having two fingers worth....
13th May 2020, 07:50 AM
#17
Well a new development with the cause of the throttle failure. I removed the micro switch and as an after thought I re tested it with a multimetre. It worked fine as per specs. No resistance with pedal up, resistance when pedal down. I then noticed that the neoprene buffer or button, similar to the one between the brake pedal and brake light switch, was stuck on the micro switch side of the assembly. It was not allowing the switch to disengage and complete the circuit. The same has happened with a few cars I've owned where the button on the brake pedal falls off and leave the brake lights on until you notice the issue or you have a flat battery. Never had one stick before.
All the time and effort........ Anyway, I won't be needing a new switch after all.
The Following User Says Thank You to Homebrew For This Useful Post:
