9th May 2020, 11:13 PM
#321
mudski
I'll find some 1mm or 1.5mm plate from somewhere and use that. I have some 3mm plate but its too hard to work with and shape.
Yell out if you need some steel. I could grab some from work. Have both 1 and 1.6mm.
The Following User Says Thank You to jay see For This Useful Post:
9th May 2020 11:13 PM
9th May 2020, 11:23 PM
#322
jay see
Thanks John. 1.6 would be ideal. I don't need a lot. I'll see if I can get something local if not I'll contact you.
10th May 2020, 07:36 AM
#323
Valley Steel Sales next door to our depot are very handy but not open on Sunday. Bunnings should have some sheet enough to do the job anyways. Drill some holes and do some plug welds might be a good way to go, have a practice first lol. .
10th May 2020, 09:35 PM
#324
So I got zip done this weekend. Will try and do some repairs during the week to get this sorted.
11th May 2020, 08:52 PM
#325
Mudski's High Warn High Mount Rebuild into an ARB GU Bar
Slowly but surely. Will mig this 1.6mm plate into place. I’ve cut out as much rust as I can. The rest has had a good soak in the rust treatment stuff. The plates are a fair bit bigger than the affect area. I know doing a remove and refit is the best choice, but I am really not sure on what to do so this is what I’ll do and I’ll worry about it later. Good practice anyways.
Oh! And!
The Following 3 Users Say Thank You to mudski For This Useful Post:
MudRunnerTD (12th May 2020), PeeBee (11th May 2020), Rossco (11th May 2020)
14th May 2020, 09:05 PM
#326
Got a bit more done tonight.
Not the best at welding but....
Both sides done, sealed up with Sikaflex and then painted.
Now to get back to getting this high mount into the bar.
The Following 4 Users Say Thank You to mudski For This Useful Post:
jay see (16th May 2020), PeeBee (14th May 2020), Rossco (15th May 2020), rusty_nail (19th May 2020)
19th May 2020, 08:03 PM
#327
Ok. She’s ready for the cut n’ shut. With a fubar’d back it was enough just getting the bar up on the bench.
Family4x4 (23rd May 2020), PeeBee (19th May 2020), Rossco (20th May 2020)
22nd May 2020, 08:04 AM
#328
Well I measured it all out. Got the grinder and cut away.
I want to fill in these holes in the bar too while I’m at at.
Cremulator (22nd May 2020), jay see (22nd May 2020), PeeBee (22nd May 2020), Rossco (22nd May 2020)
23rd May 2020, 09:55 PM
#329
Filled the odd shaped hole in on the top and the two large round holes.
Not a bad job for a noob welder.
Just waiting on an answer from ARB if the rubber bumpers are still available before I cut them out. The bolts holding them in are really rusted and need to be cut off.
I’m trying to get another weld on two aerial mounts from ARB as well. ARB being a customer of mine I have a few contacts on the inside so hopefully they come through with the goods. I might have to hit them up for some BP’s too I reckon.
Gotta weld in this plate to fill the front hole too.
It used to have a W in this hole for Warn.
23rd May 2020, 10:02 PM
#330
What hole? Nice work Mark, also nice welding safety moccos.
In any moment of decision, the best thing you can do is the right thing, the next best thing is the wrong thing, and the worst thing you can do is nothing.
Theodore Roosevelt
The Following User Says Thank You to Family4x4 For This Useful Post:
