Page 32 of 91 FirstFirst ... 2230313233344282 ... LastLast
Results 311 to 320 of 904
  1. #311
    Mudski's High Warn High Mount Rebuild into an ARB GU Bar
    Mark, how much of a job to replace this sub assy - is it bolted or spot welded in place. I suspect the corrosion will be extended on those members - I work in an acid plant attached to the mine and see this sort of thing all the time - once it starts the cancer grows quickly. Sure you are not in the same situation however I think chasing this locally is going to end in tears and frustration unfortunately. Really sorry to see this, feel for you.
    The rust is only in those pics but maybe a centimetre or so further out. It’s only where the double wall sections are. I has put my inspection camera in the lower rubber section and there’s nothing.
    So everything you see in this pic from the engine forward. Needs to come off.
    Which means a/c, radiator assy, power steering oil cooler, lights, fans all wiring and what else there is. I have been told this will be spot weld in place too. I’m trying to see where but haven’t found yet. Plus I may need to loosen the second and maybe third row body mounts so I can remove the front mounts. If I do, that also means removing the front seats and carpet to access the bolts. Not sure if I need to do this though.
    Time to stop and drink some whiskey and think on it. This is a lot to sink in.
    I could hit it with acid to clean it up. Then have a crack at patching it up and hoping for the best.
    Or. Start stripping her down.
    I could be worse Phil. And be jobless. As much as it’s pissed me off....
  2. The Following 2 Users Say Thank You to mudski For This Useful Post:
    PeeBee (8th May 2020), Rossco (8th May 2020)
    193 Post(s)
    Yeah definatly worthwhile sitting down with a bevvy to think through even sit on it for a night and have a fresh look in the morn always helps. .
  5. The Following User Says Thank You to Rossco For This Useful Post:
    mudski (8th May 2020)
  6. #313
    Looks like you've got a big job there Mark. Thanks for reminding me never to look there. If time permits I would be changing it. Unless you're planning on moving it on.
  7. The Following User Says Thank You to jay see For This Useful Post:
  8. #314
    Yeah it is a big job. Never done it, nor can I find any info/ inter web build threads etc about what’s involved. So I’m going in blind pretty much. I think tomorrow, I will unbolt the front body mounts and see if I can jack the body up enough. Or something. Just to gauge on the job what lies ahead.
    I’m a bit confused on where or what to do to be honest.
  9. #315
    Be easier to get a wreck and replace that bit?
  10. The Following User Says Thank You to rusty_nail For This Useful Post:
    PeeBee (9th May 2020)
  11. #316
    193 Post(s)
    Yeah patrolapart would surely cut that bit out to graft in. Bit of stuffing round but at least it's not visible so doesn't matter if it's not a bang on job. .
  12. The Following 2 Users Say Thank You to Rossco For This Useful Post:
    PeeBee (9th May 2020), rusty_nail (9th May 2020)
  13. #317
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    Do you know a panel beater to ask? Surely there have been Patrols with front end damage where those bits had to be replaced.
  14. #318
    I have decided to cut the damage out and weld in a plate.
    I think.
  15. The Following User Says Thank You to mudski For This Useful Post:
    Rossco (9th May 2020)
  16. #319
    I reckon that's a good choice mate and is 100% what I would do.
  17. #320
    Have you seen my welding? I liken it to chicken poo...
    But. I'll give it a crack! If I fail. Then I go to plan C. Drive it into a tree Lol. I'll find some 1mm or 1.5mm plate from somewhere and use that. I have some 3mm plate but its too hard to work with and shape.
