1st May 2020, 05:25 PM
#41
Ben-e-boy
Looking on the website, there seems to be 3 different units. 1 for GQ's, 1 for GU utes and Pre 01/2000 wagons and 1 for GU wagons from 01/2000 to current.
Do you know which one you were given?
Edit. If and when you get a new one, get a measurement of the panhard and compare it before you rip the current one out.
With the springs. Your are trying to get bulk travel, load carrying capacity and a fairly low lift with off the shelf items. Something will have to be compromised. That's your issue. Sell the ones you have and try again.
I went through 6 sets of springs before I found a set I liked.
Ben I reckon he might have been given either the GQ kit or the pre GU kit. One difference I know of is the upper panhard bush on the later GU one is that big spherical type bush.
1st May 2020 05:25 PM
1st May 2020, 06:53 PM
#42
Smart like tractor
mudski
Should that make a difference to the overall length and adjustability of the panhard? As far as I'm aware there should be no difference in mounts between Q and U h233's from the centerline of the housing, that's why so many parts are interchangeable. I thought the difference is closer to the hubs or the end of the axle tube, just like the front.
96 GQ coil/Cab
08 G6eT
1st May 2020, 07:03 PM
#43
mudski
You boys are correct I had a Gq rear panhard and I knew it was wrong because I found the Gu ones on there web site but when I asked about it I was told they are all the same,I thought it that was true then why have they labeled them differently well when I was ordering more parts I told the guy that I had a Gu set up underneath and he said that he was glad that I had told him because some parts are different underneath that is when I asked him about the rear panhard and he told me that I have the wrong one because mine was for a Gq well I knew that from the beginning now I have someone that believe me
1st May 2020, 08:20 PM
#44
Ben-e-boy
No. Well as far as I am aware. It’s only a chassis mount bush design change. Length on the GU remains the same. And the Gu Panhard has a bend and the Q is straight. Again. As far as I am aware. Lol
