22nd April 2020, 10:29 PM
GQ Patrol - No Keys
Hi Team,
I just purchased a "Project" 97 Patrol RX Turbo Diesel..its in need of a fair bit of work. I had it transported to my garage , the previous owners have lost keys...so the first job is...either change ignition barrel/key or is it possible to get key cut to suit ?...cheers in advance for any info.
22nd April 2020 10:29 PM
23rd April 2020, 09:48 AM
either way the barrel has to come off, so find a cheap second one or take barrel to key cut place to get a replacement key for that barrel and hope they don't change the key format /foot print, that way you can you it for other doors on the patrol
![](image.php?s=e8edfec642b6f412483775febba51c17&u=6260&type=sigpic&dateline=1353296412)
The Following User Says Thank You to altech For This Useful Post:
Kiwi1968 (28th April 2020)
23rd April 2020, 02:51 PM
most qualified locksmith can make a key to fit the ignition unless its too worn. If it was one key to suit all locks then it will still fit all locks.
Pete
23rd April 2020, 02:52 PM
most qualified locksmiths can make a key to fit the ignition unless its too worn. If it was one key to suit all locks then it will still fit all locks.
Pete
23rd April 2020, 03:05 PM
Get locksmith to re-key the locks so the old "Lost" keys can't be used.
23rd April 2020, 04:17 PM
Ask Nissan for the lock codes then go to a real locksmith, not a Mr.Minute, and they can cut new keys by the code. I did this with my own Patrol.
Yeti's Beast (23rd April 2020)
28th April 2020, 02:47 PM
