21st April 2012, 12:12 AM
I am he, fear me
ripper
Old thread I know, but were you towing the camper in D or 4th?
Just trying to work out how much weight you can safely tow in OD.
As soon as I cleared the town 80 zone I would lock it up and go from there.
Along the flat or shallow downhill was all in OD with the TC locked.
Slight uphill I would drop the OD out and stay locked in Drive
Steeper uphill and I would switch off the Lock up and let the Tranny work normally and lock up as soon as the load was off the engine.
Steeper downhill or coming into lower speed zones if engine braking required I would leave the TC locked and just work back thru the gears.
21st April 2012 12:12 AM
21st April 2012, 12:18 AM
Thanks, that gives me a bit to work with.
1989 GQ LWB Wagon, TB42 Petrol/LPG Auto. Bought Dec 2010
21st April 2012, 12:22 AM
I am he, fear me
ripper
I should add that mine was a series 2 running 33's and I would usually have the Tranny mode selector in "power" but 90% of the time select the gears myself IE I'd be looking for a change down/up before the tranny ECU would be.
21st April 2012, 12:25 AM
17th March 2020, 04:50 PM
I know this is a very old thread, but someone may be able to help. My Safari (import to nz) is a 96 td42t auto with 95 in big numbers on the tcu. Safaris in nz are generally 24v although mine is 12v like a nz new or oz patrol. It does not have a pin 22 wire if the way I am counting is correct... top right down the first block of pins, and then top left down so pin 22 would be the bottom left pin on the top group of wires. Is this right? The whole setup is in and tested with just the solenoid wire to connect, can't wait to use it! Thanks in advance
18th March 2020, 02:07 PM
Kiwiape
My Safari (import to nz) is a 96 td42t auto with 95 in big numbers on the tcu. It does not have a pin 22 wire if the way I am counting is correct... top right down the first block of pins, and then top left down so pin 22 would be the bottom left pin on the top group of wires. Is this right?
Here's the pin chart I used. Does yours look the same?
http://www.nissanpatrol.com.au/forum...3&d=1335615282
Before I cut the lockup solenoid wire, I went for a drive with a test light on that wire to make sure it was the right one. Easiest way I know of to get a connection for the test light into there is to stick a sewing pin through the wire and then put the test light on to the pin.
18th March 2020, 07:24 PM
#17
Thanks ripper, but no. It has one big blue plug with a bolt holding it in place. Your method is how I am testing for the correct wire, but I am unsure as to what volts the correct signal should give unlocked and locked...
18th March 2020, 08:45 PM
#18
Mine feeds 12v out when the lockup solenoid is working, and zero when it's unlocked Kiwiape.
19th March 2020, 06:05 AM
#19
Great, that's what I was hoping to hear. There have been reports of indicator leds glowing weakly while unlocked, indicating a low voltage signal. I'll just disregard that and look for the locked signal and hope it's the right wire...
19th March 2020, 07:02 AM
#20
20200318_180444.jpg this is what I have
