14th March 2020, 09:38 PM
ZD30 ... 2.75" vs 3" ... which do you rate?
I find these days I'm just not getting enough sleep at night, drinking too much, always crabby, workin too hard and not being paid enough.
I'm pretty sure a new exhaust is the answer to all my problems. Pretty sure that will sort me out, although my trouble is I'm torn between a beaudesert 2.75" and a redback 3"
Price difference aside, which one do you rate and why?
14th March 2020 09:38 PM
14th March 2020, 09:53 PM
Can't comment on the red back as i never had one, nor any other brand for that matter. Some might say it's just a shaped piece of pipe, what can go wrong with it ... So, I don't know.
But can highly vouch on the Beaudesert systems. Had one on my navara, then on the Patrol 3L crd and now on the 4.2. Great fitment on all of them.
I had the 2.75 on the CRD and it's done it's job just fine.
15th March 2020, 12:14 AM
I had a Redback on my Zd and now on my TD. The main differences between brands is type of steel used. Some will be just mild steel, some will be aluminised steel and some stainless steel. Mild steel is the cheapest, and stainless being the dearest. Other differences will be quality of the muffler and Catalytic converter used. Cheap systems will just run a cheap cat, kinda pointless on a bigger pipe, hi flow is what you want. The last factor that many dont look at is the flanges. Some use a two bolt system, some three and some four. The more bolts the better the joins will seal.
As for size, my Direct injection ZD had 3inch. Some say 2.75 for the CRD. I think that’s bollocks personally. There’s litterally no difference between a Di and CRD motor that requires a smaller exhaust by 1/4 of an inch. I would put money of the table that if a dyno run was done on either motor with each size pipe the results would be negligible. Or zero. The idea of the 2 3/4 inch system was created by Beaudesert themselves years ago, I believe purely as a marketing ploy for their pipes. Which seems to have worked in some way.
My job is in filtration and exhaust. I sell the raw materials to exhaust shops, albeit mostly for engines much larger than a Patrol itself, but I do sell a bit to this industry, so I’ve seen a bit.
So. There’s my take on it.
