12th August 2018, 09:11 PM
Using a TD42ti pump in a GQ (wiring question)
I have just fitted an 06 TD42ti motor into my GQ and just curious if anyone has a work around for the TCV on the pump and tacho sensor?
I don’t have the factory ECU, using a GQ loom, have read about using a Hobbs switch to “trick” the TCV and using a spacer on a GQ tacho sensor but can’t find any real information about either.
I will eventually be replacing the pump with a full mechanical pump but not flush with cash either so looking for a temporary work around, thanks in advance....
Just another Blue over Silver GQ with another TD conversion
12th August 2018 09:11 PM
13th August 2018, 07:48 AM
Administrator
I can't help with the pump but yep I had to put a spacer on the sensor and it worked fine.
Below 800rpm though the needle flutters a bit.
The Following User Says Thank You to AB For This Useful Post:
Reddave (13th August 2018)
13th August 2018, 06:53 PM
Administrator
I got the spacer from Patrolapart mate, let us know if you want more info mate, thickness, etc.
13th August 2018, 08:55 PM
AB
Thanks, I’ll call patrolapart in the morning!
14th August 2018, 08:46 PM
Called patrolapart this morning, they don’t have the spacers so I made my own!
Now have a working tacho, just need to sort out the TCV wiring now
The Following User Says Thank You to Reddave For This Useful Post:
14th August 2018, 10:03 PM
Administrator
Nice one!
Does yours flutter or drop under 1000rpm?
14th August 2018, 10:23 PM
Sits fine, will see what it does when I can actually drive it, which will be in a few days
23rd April 2019, 09:18 PM
#8
Hey Reddave,
how did you go with the Ti pump and the hobbs switch.
I'm trying to put the Ti pump onto my silvertop.
1st May 2019, 08:31 PM
#9
Got it all sorted, but will be coming off soon to put a bigger pump in.
Let me know what you’re stuck on and I’ll try help out
27th January 2020, 12:04 PM
#10
Hey mate digging up the past
[QUOTE=Reddave;783161]Got it all sorted, but will be coming off soon to put a bigger pump in.
How did you get this sorted mate i cant stop mine rattling it's head off and missing at idle
