Page 39 of 51 FirstFirst ... 29373839404149 ... LastLast
Results 381 to 390 of 505
Thread: Building the 'expedition' box - looking for ideas and input
  1. #381
    A free awning although quality wise aint even close to the same league!
    Problem solved :-)
    Thank God!!! I was gunna push it off the boat half way across Bass Straight mate!!! Bloody Hell!! Just dragged the whole team down!! Looking much better.
  2. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    FNQGU (8th January 2020), MB (8th January 2020)
    Patrol Guru 0-TJ-0's Avatar
    Jan 2017
    South Australia
    11 Post(s)
    Problem solved :-)
    Those awnings don't stop a great deal of UV @MB. Just in case you're ever planning on spending a long and hot NYE under it.. Take your sunscreen as well!
  5. The Following 3 Users Say Thank You to 0-TJ-0 For This Useful Post:
    FNQGU (8th January 2020), MB (8th January 2020), PeeBee (8th January 2020)
  6. #383
    475 Post(s)
    Reconfigured the old family wagon this afternoon since removing the Titan 85kg drawers a month or so ago now.
    Managed to squeeze in so far:
    80L Waeco old fridge
    26L Engel freezer
    2 x 20L HDPE water jerry cans
    1 x camp stove
    1 x camp table
    1 x 120W Waeco old solar kit
    4 x Expedition boxes up top.
    Will fill in all the leftover nooks and crannies tomorrow now with bits and bobs and reckon sleeping bags and self inflator mattresses should jam up on top of 3 x Expedition boxes to the ceiling before dropping in the final fourth awesome box!
  7. The Following User Says Thank You to MB For This Useful Post:
    FNQGU (14th January 2020)
  8. #384
    475 Post(s)
    Approximately 1.5 sheets of ply used, and is relatively easy to install/remove if need be as long as you have the left barn door aftermarket bracket to open wider than stupid GU OEM design!
  9. #385
    475 Post(s)
    Forgot to add that I needed to extend forward 80mm this specific brand GU cargo barrier to fit the second rear row of Expedition boxes.
    They fit like a pair of good gloves now
    FWIW: The ply box outer dimensions today were:
    1125mm Wide x 930mm Deep x 540mm High and used 3 of the 6mm OEM bolt holes in the floor to secure down.
    (There is a niggly notch on the floor sheet test first before building that needs to be cut out located on the right side pictured below)
  10. The Following 2 Users Say Thank You to MB For This Useful Post:
    FNQGU (11th January 2020), Winnie (11th January 2020)
  11. #386
    FNQGU's Avatar
    Jun 2013
    Cairns, Queensland
    21 Post(s)
    Nice work! What sort of weight saving do you think you've achieved? There'd still be a bit of weight in the ply setup.
  12. The Following User Says Thank You to FNQGU For This Useful Post:
    MB (11th January 2020)
  13. #387
    475 Post(s)
    Not exactly sure Ben mate but I’d say 50kgish difference between Titan drawers and ply.
    I’ve added that back in and then some more now with heaps of gear though :-)
  15. #388
    475 Post(s)
    Decided to give the little Engel freezer some better heat release holes as its motor is on the rear exhausting upwards unlike the Waeco exhausting to rear barn door gaps.
    Perfect gap found between the two rows of Expedition boxes and directly above the Engel exhaust.
  16. The Following 3 Users Say Thank You to MB For This Useful Post:
    FNQGU (14th January 2020), Rossco (11th January 2020), threedogs (24th January 2020)
  17. #389
    475 Post(s)
    Some 12mm x 12mm aluminium angle from Bunnings seems to stop the slide left and right.
    Sleeping bags jammed hard on top of the first row and against the rear cage seem to negate the need for strapping down.
  18. The Following 2 Users Say Thank You to MB For This Useful Post:
    AB (11th January 2020), FNQGU (14th January 2020)
  19. #390
    583 Post(s)
    All packed ready for an adventure, my Gq looks like an expedition box touring advertising festival bonanza lol
  20. The Following 8 Users Say Thank You to AB For This Useful Post:
    Clunk (13th January 2020), FNQGU (14th January 2020), MB (11th January 2020), MB TD42 (13th January 2020), mudski (11th January 2020), Plasnart (11th January 2020), Rossco (11th January 2020), threedogs (24th January 2020)
