Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Death Wobble at 80km/h
    Aug 2019
    I have the usual GU death wobble and was wondering what people have done to fix it? I have a hunch it will just need the radius arm bushes to be replaced but i'm not sure
    465 Post(s)
    You will have better luck with next weeks tattslotto numbers than finding a definitive answer to what fixes the issue. In my case it was poorly balanced wheels. But I had to replace every bush under the front to find this out. Lol.
    Panhard bushes, radius arm bushes, bearings, as has already been said, can be caused by a multitude of things.
    193 Post(s)
    Yeah panhard is a good place to start, pump some grease in the tie rod & drag link ends if that fixes it they've got a bit of play. Check wheel bearings are tight and swivel hub bearings too.
    Expert Yeti's Beast's Avatar
    Aug 2016
    Jimboomba
    4 Post(s)
    Buying new tyres fixed it for me
    Dec 2019
    Western Sydney, NSW.
    Picked my GU Cab Chassis up 7 Days ago, had the same problem with the Death Wobbles at 80klm.
    Started off with:
    - wheel balance and alignment . . . No Change
    - tighten up wheel bearings. . . . No Change
    - remove king bearing flange . . . All Good - No wheel wobbles
    Grant
    Expert pollenface's Avatar
    Nov 2019
    Perth
    5 Post(s)
    Quote Originally Posted by Grant209 View Post
    Grant
    Can you post a pic of this flange? I'm not sure what the actual part is. I have the same problem.
    2008 CRD Auto Wagon
    175 Post(s)
    Quote Originally Posted by pollenface View Post
    It's a shim. Here is a good video where this bloke removes the shim and fixes his wobbles.
    Also here is @MudRunnerTD 's post showing a good diagram of it.
    http://www.nissanpatrol.com.au/forum...l=1#post657612
    Nov 2019
    Perth
    5 Post(s)
    Yeah I actually found that vid soon after, cheers. Looks like you can order any size shims on ebay.
    2008 CRD Auto Wagon
  11. #10
    Dec 2019
    Yeah Sorry pollenface, it's been a busy week or so for me.
    If you haven't already played around again . . . . . here's my reply.
    You shouldn't need to buy any New Shims, it's the removal of One (1) Shim from each of the Bearing Caps (Top & Bottom from each hub) that should fix the Death Wobble Problems as the video "Hodge" posted shows how to do so that you will be looking at, removing the Shims increases the pressure on the Inner Bearing onto the Swivel Hup, and with any luck the removal of your Death Wobbles.
    If it dose not stop your Death Wobbles, then you may be looking at replacing your Four (4) Inner Bearings, this should be the only reason why you would need to buy New Shims, as the a result of your Inner Bearings being worn and needing replacing, then you would also need to replace your shims too . . . . I think.
    Now I've only owned a SWB Landcruiser with a Solid Front Axle before, and it had a whole heap of issues in the front end which gave me death wobbles too, my Landcruiser went through a full front end suspension rebuild, so I don't really know what was behind it's death wobble issues, more then one I think.
    The video Hodge posted and I think you said you have watched, is the same video I watched before I did my shims. It's very simple and straight forward to do. You will probably fuck one of your shims trying to get the Bearing Cap off. All up it took me about 2hrs all up to remove One (1) shim from each of the Four (4) Bearing Cap.
    Grant
    Penrith Region
    Sydney NSW.
  12. The Following User Says Thank You to Grant209 For This Useful Post:
    pollenface (13th January 2020)
