7th December 2019, 12:14 PM
Jumper Leads???
Went to eBay to get some jumper leads, didn't think much about it.
200A, 700A, 1200A, 3000A.
What capacity leads do I need for the ZD30???
Thanks guys.
7th December 2019 12:14 PM
7th December 2019, 12:32 PM
Patrol Guru
They are always shit quality wire so buy the biggest you can afford never hurts to have bigger in this case.
But to give you an idea I've jumped a car with tiny wire before. It just gets hot. Too small or if battery is too dead and it corks smoke the wire on smaller ones
Sent from my Pixel 3 using Tapatalk
The Following User Says Thank You to matfew For This Useful Post:
04OFF (7th December 2019)
7th December 2019, 12:34 PM
Hardcore
From my humble opinion and my own experience, the larger the cable core, the better, especially if you want to start a Diesel
7th December 2019, 01:06 PM
7th December 2019, 02:29 PM
Yeti's Beast
Holy crap YB, you must do a lot of jump starting?????
The Following User Says Thank You to 10G For This Useful Post:
Yeti's Beast (7th December 2019)
7th December 2019, 04:16 PM
Jumper Leads???
10G
No
I acquired them through work ![](http://s3.amazonaws.com/tapatalk-emoji/emoji1787.png)
7th December 2019, 04:17 PM
Smart like tractor
Lol...those rating are a joke.
Just buy the largest cross sectional area you can afford. Or go and buy your own cable from a electrical supplier, nice big clamps from an industral/ welding supplier and make your own
Edit..... for shits and giggles.
For a (true-ish)3000A, 6m long jumper lead set, you would need parallel 630mm2 leads (2 per lead). 630mm2 is 6.3Kg/M, x 24m = 151.2Kg of cable.
96 GQ coil/Cab
08 G6eT
![](image.php?s=66df2f7bd9ace6999750a12f7fbfbe48&u=1281&type=sigpic&dateline=1483248064)
7th December 2019, 04:49 PM
#8
70mm2 welding leads with good clips will start anything in any weather. I have 8m leads and they sit nicely in a canvas bag in the back. Check out a welding supplier or surf around for a good price. Don't lend them to anyone because they wont come back - know this from experience!
7th December 2019, 04:52 PM
#9
PeeBee
Learnt the same lesson
7th December 2019, 04:59 PM
#10
Ok looks like I led you up the garden path
They looked similar. Oops
My leads are Matson brand 50mm sq
![](http://www.nissanpatrol.com.au/forums/images/imported/2019/12/64.jpg)
Still heavy enough to start most things
The Following User Says Thank You to Yeti's Beast For This Useful Post:
PeeBee (7th December 2019)
