4th December 2019, 08:56 PM
Bad oil leak
Hi guys, I have a 2011 manual 3l CRD. I've just noticed there's an oil leak which I suspect started last night or this morning, but it has emptied out almost all the oil. Any ideas what it might be from? Thanks ![](http://www.nissanpatrol.com.au/forums/images/imported/2019/12/21.jpg)
![](http://www.nissanpatrol.com.au/forums/images/imported/2019/12/22.jpg)
4th December 2019 08:56 PM
4th December 2019, 08:58 PM
Patrol Guru
Is that the harmonic balancer? Front main seal?
4th December 2019, 09:03 PM
0-TJ-0
I'm not 100% sure, it's just been gushing out since around this morning
4th December 2019, 09:51 PM
Patrol Guru
M.Johnson
It's a little hard to see what's going on, and I'm not used to looking at the 3l.. But looks like it's all coming from around the balancer.
Pop over and introduce yourself and I'm sure someone with a bit more knowledge than me will come along and help you out.
4th December 2019, 11:28 PM
looks like front main seal...but grab some degreaser or oven cleaner give it a clean..start it up should be able to see it pretty quick if that only started afew days ago
5th December 2019, 01:58 PM
my guess would be the front timing cover, ive seen many zd30 crd leak from the main timing cover sandwich plate.
The Following User Says Thank You to Fireblade For This Useful Post:
Hodge (5th December 2019)
5th December 2019, 02:21 PM
Fireblade
Yup.
Same, my money is on the timing cover.
