Results 1 to 3 of 3
Thread: Zd30 crd turbo
    Sep 2019
    Zd30 crd turbo
    Could someone please tell me what type of turbo is on the 2010 zd30 crd please?? Im mainly after what type of turbine outlet it has ( part where it joins the turbo to the exhaust dump pipe) i have done some searching and i keep getting gt2052v but some sites say only up to 1999 model and other say from 99 onwards.
    175 Post(s)
    Hey mate.
    Receipt from Nissan dealer when my crd was replaced says 769328 5001s as part number.
    If you search that hope it helps you .
    Mine was a 2009.
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    37 Post(s)
    Garrett M24 Housing and yes CRD is GT2052V Turbo mate. Turbo has 3 studs to dump pipe (8mm dia from memory) and if u are changing dump pipe be sure to use wurth nuts, they should be copper coated with a lock ring on top.
  5. The Following User Says Thank You to Bidja For This Useful Post:
    Stump2jz (30th September 2019)
