19th July 2019, 05:52 PM
ipad charger
using the ipad air2 for navigation and engine parameters but the cig socket chargers will not keep it charged (2.4a). If I turn down the brightness of the display it gets to the point where you cannot see it during daylight hours. What are others using?
19th July 2019 05:52 PM
19th July 2019, 06:31 PM
Moderator
Buy a new charger. The 2.4amp should do it. Maybe if it's a cheap one it is not getting 2.4amps out.
Samsung do a higher output one worth chasing.
Check out my Toy -->
Rogue Dung Beetle
I've been having this issue too!
My phone gets too hot on the cradle with the navigation on and charging, it's either too slow or overheating.
Friend of mine is using a VMS unit - seems pretty happy with it.
19th July 2019, 06:47 PM
Not much help but have a Samsung galaxy tablet which keeps up fine. Is the charger a cigarette lighter socket or usb, found some of the usb ones with adapters can be pretty slow.
19th July 2019, 07:14 PM
Daily Lurker
are you using a factory apple cord? cheaper ebay like cords are in some cases not up to par with the demand. i think you might find for a tablet, on full screen brightness with wifi and bluetooth turned on, you would be more needing a 3.2 amp charger? also another option could be: not sure if apple are compatible with the 9V fast chargers but i know 5v/9v high amp fast chargers for cars are available, thought might suit your needs also.
19th July 2019, 07:15 PM
just had a look at both of mine. Even thought it is stamped 2.4 amp, the fine print says nominal charge 1.0 amp ?????? WTF does that mean .. it's a single usb charger .. there's the problem
The Following 3 Users Say Thank You to timbo2410 For This Useful Post:
AB (20th July 2019), MudRunnerTD (19th July 2019), rusty_nail (19th July 2019)
20th July 2019, 12:06 AM
No doubt the least techy qualified someone here, but here’s my nuffy findings.
iPad old old biggin on the bush ute dash with memory mud rooftop maps kindly setup by the NP.com.au top blokes only seems to charge off an original iSteal Apple cord.
iPhone for work too spits the dummy with service station emergency bought cords also after only a short while. Needed to bluetooth earpiece work call blokes whilst bouncing away in old noisey twucks and found this wanky ripper only likes OEM charge leads too!
![](http://www.nissanpatrol.com.au/forums/images/imported/2019/07/292.jpg)
McApple I reckon has worked out how to let aftermarket gear last a few weeks then give us a pop up “device may not be supported” message thingymebob:-)
MudRunnerTD (20th July 2019)
20th July 2019, 12:45 AM
Moderator
the old "this device may not be supported" line eh!!!!. Bloody Hate that!! Like What the Actual Faaarrkk mate!! It bloody worked this morning damn you!!
Rogue Dung Beetle
The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
MB (20th July 2019), Rossco (20th July 2019)
20th July 2019, 01:18 AM
The Following 4 Users Say Thank You to MB For This Useful Post:
GQtdauto (20th July 2019), MudRunnerTD (20th July 2019), Rossco (20th July 2019), rusty_nail (20th July 2019)
20th July 2019, 01:14 PM
mines the usb type that plugs into a cig lighter socket on the patrol. It charges fine if your not using your display. Actually the samsung S8 charges to 100% even if your using navigation. But the ipad just doesnt get enough juice to charge AND use the display. I think the "NOMINAL OUTPUT 1 AMP" .. is the issue. I've got a 2.4 amp output ordered now so will see how that goes.
The Following User Says Thank You to timbo2410 For This Useful Post:
