6th July 2019, 06:39 PM
#12401
@MudRunnerTD Id be buying a second set and have them ready when they fail again.
looks weird how they failed so early
6th July 2019 06:39 PM
7th July 2019, 12:49 AM
#12402
Ben-e-boy
They failed because he STILL hasn't put a set of long arms in yet.
Or he put the left hand side in the right and vice-versa........ but most definitely not having long arms
Because the Geelong Freeway requires long arms ... I was actually thinking about whether the arms were in vice versa on the way home tonight from Matts place. Very strange to see all four fail.
7th July 2019, 12:53 AM
#12403
I got the bloody 80kph death wobbles in mine for the first time in four years. I really hope the wheels just need balancing as its really annoying and shakes quite violently. Panhard bushes are good, I know that, and the wheel bearings I have checked. Radius arm bushes are maybe 18months old....
7th July 2019, 10:36 AM
#12404
Patrol Guru
mudski
I've always wondered about this. New steering damper wouldn't help?
7th July 2019, 11:05 AM
#12405
mudski
Couple of weeks ago I had movement felt coming back thru steering whl @ 80kph and took the easy path first and had full whl balance now fine. From a glance every thing else seemed OK_all good.
How violent can the all quoted "death wobbles" be noticed within reason (eg: bonnet/front panels start to gitter)?
7th July 2019, 01:34 PM
#12406
SUCH IS LIFE
Bidja
I think usually the driver should manage the wobble by increasing or reducing speed to minimise the effect.
In me shit box GQ on the way from VHC I once tried to see what would happen if I kept the shakes going. Well besides all my insides nearly coming out my rear, I though all the panels and windows would give way...it was farked...bad, really bad
________________________
______ 2017 D-Max _______
The Following 2 Users Say Thank You to Maxhead For This Useful Post:
Bidja (7th July 2019), Rossco (7th July 2019)
7th July 2019, 01:35 PM
#12407
I am he, fear me
Bidja
snip...
'Death Wobbles' are an Harmonic Effect so if the outside factors remain constant they just get worse and worse
If left unchecked IE you don't speed up or slow down to change the harmonics then they can be violent enough to shake the entire car quite severely, certainly enough to scare your pucker valve into slamming shut.
I had a case of death wobbles on my Tray Back that were significantly more violent than the gnarliest corro's I have ever driven on.
The vehicle was frightening at anything like a constant speed between 75 to 85 KPH but happy to sit below or above that speed
The Following User Says Thank You to the evil twin For This Useful Post:
7th July 2019, 02:00 PM
#12408
Moderator
PeeBee
Darren, why do you think they failed - leaving aside quality, are they loaded heavily or twisty stuff going on exceeding their duty? They appear to have failed catastrophically I would say. What a pain.
Yeah I am putting it down to crap quality rubber. All 4 are compressed and collapsed. The arms where in the right way and the thing was rear steering it's head off.
The bushes where after market off eBay for $50 a set of 8. Damn it. Pushed out the uppers at the same time which had 320k factory bushes in. I have grabbed a set of OEM bushes from Roadrunner for $190 which where supposed to be here Friday but will arrive monday so will replace them all again. The original factory arms are back in it for a week of freeway.
Those bushes had commuted down the freeway for 8 weeks!!!! No off-road at all. The only thing they copped was a heavy right foot by Naomi.
Check out my Toy -->
Rogue Dung Beetle
7th July 2019, 02:07 PM
#12409
MudRunnerTD
I feel your pain, you just don't need the practice on stuff like this. What site did you purchase from so others can be wary? Happy for a PM on this if you prefer.
MudRunnerTD (7th July 2019)
7th July 2019, 02:27 PM
#12410
Moderator
PeeBee
Here ia the eBay link
https://rover.ebay.com/rover/0/0/0?m...2F253239892969
And here is the screen shots. I have sent my pics to the seller but don't expect a reply as I have already left positive feedback...
Rogue Dung Beetle
