Results 1 to 6 of 6
Thread: NEW auto gearbox, info required, where to buy, about how much?
    Jun 2019
    Hi Guys,
    I got water in the transmission and transfercase as the breather hose came off somehow and did water crossings. It is a 2012 3.0l wagon.
    If I was to look at purchasing brand new is there somewhere I look for a code to ensure the correct parts?
    Is there a preferred supplier for new ones?
    About how much are they?
    Will I need a hoist?
    Finally, it is not something I have done before, would you recommend diy?
    Thanks for any info.
    465 Post(s)
    Quote Originally Posted by hcns View Post
    Hi Guys,
    Is there a preferred supplier for new ones? Wholesale Automatics
    About how much are they? Got no idea...
    Will I need a hoist? No. but its bloody handy.
    Finally, it is not something I have done before, would you recommend diy? Not if your going to do it alone. Depending on how experienced you are too.
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Hi Guys,
    If I was to look at purchasing brand new is there somewhere I look for a code to ensure the correct parts? Not 100% sure on yours but possible stamped on you current gearbox pretty sure mine was
    Is there a preferred supplier for new ones? Wholesale Automatics, they might be able 2 tell you what gearbox you need over the phone just by year model or vin
    About how much are they? Bloody expensive!!!! but when you weigh up rebuilding yourself.....well just go look at my rebuild thread posted further below. Ask Wholesale or whom ever you ring about getting an exchange box
    Will I need a hoist? No, makes it easier yes, I got a metal plate made up that fitted the trolley jack which helped a lot
    Finally, it is not something I have done before, would you recommend diy? Hell yes if you have the time 2 do it yourself and half half an idea on mechanics and tools
    Check out my TB4.2 EFI auto gearbox rebuild for insight 2 what a rebuild consists of: http://www.nissanpatrol.com.au/forum...earbox+rebuild
    Jun 2019
    Thanks for your reply!
    Going to read the post linked below and get an idea if it is something that I should take on.
    Jun 2019
    Well that was helpful, I will definitely never, never, do a rebuild. HAHA!
    Have to contemplate the jacking requirements. Looks like you fabricated a couple of plates and a stand. And then have a good think, do I really want to do this!
    Kudos to you for tackling it and to your ol' man too (and his previously smick looking cement!)
    Aug 2010
    17 Post(s)
    hahahaha yeh I got a gravel driveway and no way in hell was I doing it here, easier 2 do it at my old mans as he has all the tools
