26th April 2019, 03:02 PM
Y61 automatic transmission not engaging in Drive
I have a automatic transition that in the morning it will not engage in Drive
I need to take off in second and then engage Drive
26th April 2019 03:02 PM
30th April 2019, 10:58 AM
have you checked the trans fluid level and condition?
1st May 2019, 07:07 AM
Welcome to the forum mate.
1st May 2019, 08:22 AM
Axemano
Welcome to my world, You are not alone. this happen to me 3 years ago with my 97 Gu 4.5 Ti . Went to Wholesale Automatics thinking if I replace the valve body with one of there's heavy duty one it will be fixed. but no it didn't. I'm so use to it now , I always start the car up, take of in second, get down the road then put it in drive and good all day. So if any else who know's what happening to our auto on first start, please let Axemano and myself what the fix is . cheers Alex
![](image.php?s=c9405d8aac3e2e7070ed6fb97bdc8e02&u=6260&type=sigpic&dateline=1353296412)
1st May 2019, 08:28 AM
4bye4
It's not fuild problem, as I had my Valve body replace at Wholesale Automatics with one of there heavy duty one's and now I have full Synthetic now, still have this problem only happen's when I first startup. regards Alex
1st May 2019, 11:09 AM
Ok I was using the logic that its either fluid, mechanical or electrical. Fluid seemed the easiest to check. Mechanical usually results in some noise or stiffness in operation, so possibly electrical?? Mine does not go into overdrive or whatever that top lazy gear is called, until the box gets to a certain temperature. This is controlled by the gearbox management board which in mine is located in the passenger firewall. Don't know if this can be altered or read with a scan tool to check.
1st May 2019, 12:19 PM
4bye4
I think your has to be Electrical, maybe the switch or loose wire connection somewhere regards Alex
1st May 2019, 12:31 PM
4bye4
Does the OD OFF light on the dash come On and OFF when you push the button on the gear selector?
1st May 2019, 12:36 PM
BillsGU
Yes mate. Actually I think it’s meant to be like that. I might have mislead everyone there. I was trying to guess why the op cannot get drive until his trans warms up. Mine not selecting the od until warm is I think what is supposed to happen and there is a temp sensing of some sort
4th May 2019, 09:21 AM
Sorry I have not been on the forum I don't have much time during the week
Good to see that there is someone else out there with the same problem and the fact that you have Drive for so long it puts me to rest that I might not be breaking down just yet
Have decided to change trans fluid filter and trans fluid today as a step one provision also take hey visual inspection of internal wiring
Everyone I have spoken to this week leads towards low fluid levels or fluid quality but I have my doubts thinking more Electrical as there is nothing in this car that isn't Electrical and communicates buy computer
So I think the next step after today maybe some type of scan tool that works on this model tesY61 2005 or start paying someone
