22nd April 2019, 06:52 PM
Vehicle Button Quiz
Hi Team!
I don't have an owner's manual and wondering what these two buttons do!? Stupid question to some I'm sure.
Many thanks!
The Following User Says Thank You to hoobnoob For This Useful Post:
22nd April 2019 06:52 PM
22nd April 2019, 08:18 PM
Travelling Podologist
Knob on the right is a throttle hand control for use off road when the going is slow & bouncy. Keeps you from bouncing your foot up & down on accelerator pedal & 'jerking' forward. Push accelerator pedal down to get desired revs, pull out knob & turn to lock it. You can then take foot of accelerator & maintain revs. It's a good idea that used to be common, but seems to be missing from many modern 4wds. Dunno what RR Heater switch does, don't have one in my car.
22nd April 2019, 08:36 PM
Cuppa
I think thats what a few use that for Ian, but I believe its was actually intended for was the use of PTO driven devices. Not 100% sure though.
threedogs (24th April 2019)
22nd April 2019, 09:20 PM
Breadmaker Shaker
Cuppa
mudski
Yeah could be used for both. Basically to keep engine revs constant. In my childhood saw milk cockies using this function to keep vehicle driving slowly through paddock while dishing out feed from the tray. Not worksafe approved these days I'm sure, been many a farmer driven over exiting or trying to re-enter.
The Following User Says Thank You to Plasnart For This Useful Post:
22nd April 2019, 09:44 PM
mudski
I also use mine if running my compressor whilst stationary, just set the revs to about 1200rpm. Using it as I described when driving is a skill that needs practice, I've only done it a couple of times set at 2000rpm & 'made adjustments'with the clutch.
22nd April 2019, 09:50 PM
Cuppa
Yeah I've never used it for steady hill climbing. Maybe I should one day.
23rd April 2019, 10:26 PM
mudski
I may get an opportunity to give it another try in a few weeks time when we take on the Munja track with tvan in tow. I'm told there are a number of 1st low long steep & rocky jump ups . I reckon the e-locker might get a workout too.
24th April 2019, 07:43 AM
RR heater is the heater for the rear seats. SLX model?
The Following User Says Thank You to parelius For This Useful Post:
rusty_nail (24th April 2019)
24th April 2019, 01:35 PM
Cuppa
Its called Toyota lurch, been around for ages, lol
24th April 2019, 01:40 PM
mudski
More for flat rocky sections , not hill climbing.
I used to jump out of my other 4x4 and direct
the "ghost" driver,, had others in the convoy scratching their heads.
Flat ground only. a must for any 4x4 IMO.
@hoobnoob is that a Tojo ute or troopy
