Results 1 to 5 of 5
Thread: Spring and Ball Boost Controller Mod
    Apr 2019
    Kalgoorlie , WA
    Hi All
    Made a mod to my spring and ball boost controller that may be usefull to those with spring / ball jamming or sticking issues.
    I removed the ball altogether and replaced it with a counter sunk screw that is only slightly smaller than the I.D. on the controller but larger than the spring diameter.
    Have attached a pic to make my ramblings easier to understand.
    max boost is now on 18psi with needle valve open 1/4 turn for about 10psi at 100km.
    There is no boost spike or jumpy needle as before which I suspect was from the ball / spring.
    Having the screw shank go down the barb keeps everything inline and moving freely.
  2. The Following User Says Thank You to R055IE For This Useful Post:
    4bye4 (16th April 2019)
    Good idea.
    I reckon you might want to file down the teeth on the screw so theres no chance of it catching.
    Apr 2019
    Kalgoorlie , WA
    Good idea Mudski,
    I Will keep an eye on it , sticking etc should show up on the guage as a jumpy needle
    thanks
    Maybe even cut it in half ,all trial and error I suppose
    Apr 2019
    Kalgoorlie , WA
    Hi All ,
    Update , I have had no issues at all with the screw mod in the boost controller over the last few weeks , it’s set at around 20 psi with the needle valve at 1/4 turn , gauge shows to sticking or boost bounce
    Currently working out remote for the last couple weeks so it’s getting a lot of bush track / no track testing.
  8. The Following User Says Thank You to R055IE For This Useful Post:
    mudski (2nd May 2019)
