Page 460 of 568 FirstFirst ... 360410450458459460461462470510560 ... LastLast
Results 4,591 to 4,600 of 5672
  1. #4591
    195 Post(s)
    Bought another Quicktifier 420 external rectifier kit for my second alternator. This adds another 12 diodes to the standard alternator and improves efficiency and duty cycle. I have been running one for the last couple of years with great success. Highly recommended.
    2019-04-12 Quicktifier 420.pdf
    MB (12th April 2019)
    Adventurist stevemc181's Avatar
    Jan 2017
    Thornlie,Perth WA
    8 Post(s)
    A new Enerdrive DCDC charger for the LifePo4 battery I have. I've been using a redarc BCDC1225-Lv for the past 5 years, it's done the job ok, but is too slow to charge and doesn't have a lithium profile. The redarc also meant I had to use the shitty changeover relay setup that the older redarc models used for solar.
    2016 GU Legend Edition: 3505Kg GVM Upgrade and Stuff!
  5. #4593
    174 Post(s)
    Quote Originally Posted by stevemc181 View Post
    A new Enerdrive DCDC charger for the LifePo4 battery I have. The redarc also meant I had to use the shitty changeover relay setup that the older redarc models used for solar.
    Good choice I reckon, was looking at them recently. The Redarc BCDC1240 (also with changeover relay setup) is keeping us going ok, but when the day comes that either it karks it, or batteries need replacing (with lithium) then that's what I'll buy too.
  6. The Following User Says Thank You to Cuppa For This Useful Post:
    stevemc181 (12th April 2019)
  7. #4594
    Jan 2018
    Pt Augusta SA
    Too much now to lie about the cost to her indoors
  8. #4595
    Yes Phil installing modules underneath roof rack / mesh is a great concept . Provides unimpeded access to rack for stowage on top, provides tropical type roof shade/cooling, plenty of air circulation to back of the panel and provides protection to the module glass face in transit.
    Side mount would be a good double up as awning type shelter. If slid fwd over bonnet, apart from shade effect (front glass), it could be secured/stabilized with drop struts to bull bar to provide support against effects of windage and other loads (eg: rain/snow).
    Tropical roof is a great idea Land rover did it years ago,
    my first camper I made had a false roof by using my solar panels
    cool as inside even in the blazing sun
    when the price comes down on lithion batteries Ill buy one as well
    but cant see it happening in the near future, $2000 for a battery is
    a tad much if you only use it say 6 times a year
  9. #4596
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    37 Post(s)
    @threedogs yes do remember the LR tropical roof. Have done the cork tile roof and side thing and of course very familiar with the internal drips from condensation off metal roof inside sleeping.
    Batteries have improved a little over the last 20 or so yrs but lagging well behind for storage in independent pwr sys and remain expensive. Have been off grid now for 30yrs and still use FLA batteries, interesting the first PV modules I bought(1990) and still using some today were Australian made BP275 (75watts) @ $650 each '90.
    My fishing trips (high country) usually away 2 night(generally stay put), only demand is Engel 40lt and LED light strip so manage well with deep cycle nom 100Ah Lead Acid battery in eng bay - no PVs.
  10. #4597
    LED lights have made battery managment much easier
  11. The Following User Says Thank You to threedogs For This Useful Post:
    Bidja (13th April 2019)
  12. #4598
    Super Cheap have 40% - 60% off store wide
    good chance to get some oil and filters for
    future services
  13. The Following User Says Thank You to threedogs For This Useful Post:
    0-TJ-0 (18th April 2019)
  14. #4599
    WA Wheatbelt
    23 Post(s)
    What did I buy today? I bought lunch. lol
  15. #4600
    Took the boss out for a good serve hey grunta
  16. The Following 2 Users Say Thank You to Avo For This Useful Post:
    DX grunt (19th April 2019), rusty_nail (19th April 2019)
