25th March 2019, 05:47 PM
#71
Smart like tractor
altech
Hi Guys, the Big and bloody heavy battery arrived today, hmmm did I mention heavy lol. Did some improvements / upgrades to the battery wiring. Now waiting on the real MPPT charger to arrive. keep you posted regards Alex
Attachment 78214
Attachment 78215
I have a few Questions.
How did you crimp the larger cables?
What the go with that figure 8 cable to the the Negative and what size is the main negative?
96 GQ coil/Cab
08 G6eT
25th March 2019 05:47 PM
26th March 2019, 07:04 AM
#72
Ben-e-boy
1/ Soldered in like you would a Anderson plug. 2/ 8 gauge wire is neg and it's connected to second battery from that to my rear electric cargo barrier frame work which is grounded to the body of car.
26th March 2019, 05:03 PM
#73
Smart like tractor
Ah ok. That's why it doesn't look like they are crimped
96 GQ coil/Cab
08 G6eT
6th April 2019, 07:41 PM
#74
Hi Guys, Installed my Real MPPT controller today and works great, it does have a add on Bluetooth receiver that connect's to my phone. in the pic I have changed the wiring again lol regards Alex
6th April 2019, 07:42 PM
#75
And Yes I have MT50 receiver too.
The Following User Says Thank You to altech For This Useful Post:
Yeti's Beast (6th April 2019)
6th April 2019, 08:36 PM
#76
Moderator
altech
Wow the Cargo Barrier is pretty kool mate. What glass did you use? Assume it is profiled right? Well done mate. Fair effort indeed.
Can you post a pic zoomed out a little so we can see it up and down and maybe half up?
Check out my Toy -->
Rogue Dung Beetle
6th April 2019, 08:40 PM
#77
Moderator
You have got to fix that though mate, thats junk. You can do much better than that bud. Just say'n
Rogue Dung Beetle
6th April 2019, 08:51 PM
#78
MudRunnerTD
Not Glass, but 10mm plastic . went to dealer, he had a off cut $50 bucks, then I cut it to size
MudRunnerTD (6th April 2019)
6th April 2019, 08:52 PM
#79
MudRunnerTD
Yes did see this after the photo was taken, cheers Alex
MudRunnerTD (7th April 2019)
6th April 2019, 09:08 PM
#80
Daily Lurker
MudRunnerTD
im sure i have seen the equivalent on your beast? come on mate, not everyone is perfect
The Following 2 Users Say Thank You to rusty_nail For This Useful Post:
altech (7th April 2019), MudRunnerTD (6th April 2019)
