Results 1 to 10 of 13
Thread: Timing cover removal 2006 3.0DDi
    Gold Coast
    Question Timing cover removal 2006 3.0DDi
    I have compression issues with #1 and 2 cylinders--both fail to hold compression. #3 and 4 are fine.
    Initial diagnosis says there is a blown head gasket between those two.
    Has anyone been successful in removing the front timing cover without removing the engine. History from the "water leak" issue I had earlier says the vacuum pump shaft is too long to get the cover off, even with the radiator out.
    Any comments, suggestions welcome, otherwise I need to lift the engine out--bummer.
    Gary
    465 Post(s)
    @Hodge.
    As far as I know. Its an engine out job.
    Edit : Well. Do what I should have done when my 3ltr shat itself. Drop a Cummins it in. If only I knew back then what I knew now I wouldn't have put a TD in.
  4. The Following 2 Users Say Thank You to mudski For This Useful Post:
    Dr Gary (4th April 2019), rusty_nail (3rd April 2019)
    175 Post(s)
    If it's leaking from where I think it's leaking than it's not unusual for these motors to do this.
    My ex-3L crd is still leaking just like this. And has been since 2011.
    Common on the zd30 I'm lead to believe. Sandwich plate at timing cover.
    When I ran around looking for a fix or someone to fix it , was told it's a motor out jobbie.
    There are some posts on the other forum with people getting it done in-situ , but in the end they all said it would have been a far less tedious job if motor got yanked out. Some of them posts have a lot of info and photos.
    Personally I left mine as is and just monitor and top up once a month as required. During warmer months it virtually did not leak due to metal expansion I believe compressing the leak hole.
    The current owner which I see all the time , does exactly the same .
  6. The Following User Says Thank You to Hodge For This Useful Post:
  7. #4
    Gold Coast
    Hi Mudski: you are probably correct but I have had too many birthdays to be rebuilding at this stage. Should have done it when I had the engine out to do the water leak.
  8. The Following User Says Thank You to Dr Gary For This Useful Post:
    mudski (5th April 2019)
  9. #5
    Gold Coast
    Hi Hodge: Actually did the engine out water repair a few years back, just a slight bow in the steel plate behind the timing gear. $50 fix for $3K. This is no compression between #1 and #2.
  10. #6
    465 Post(s)
    Do you need to remove the timing cover to remove the head in the Di? Its been a while since I last looked at one of these motors. Let hope it is just a head gasket.
  11. #7
    Gold Coast
    The head carries a camshaft that runs off the timing chain at the top part of the front. That covers the drive to the camshaft, so needs to come off.
    I suspect I can get the front cover off, and that MAY be enough. I will report later.
  12. The Following User Says Thank You to Dr Gary For This Useful Post:
  13. #8
    Gold Coast
    OK so I now know the issue is the two front pistons are stuffed--not in the top but down the side. Really bad scoring of the bore in both cylinders. It looks like #2 has been hot, but I guess if a piston or rings or other debris is running up and down the bore it will get hot. No warning on EGT. Injector spray pattern and pressures are all about right.
    Does anyone know if this is a "wet sleeve" motor?? Alternative is a rebore and oversize pistons--not my preferred choice.
    This has been an expensive poor choice--I opted for the 3.0 because the kw rating was higher than the 4.2 Now I pay the price for the third time--clutch, water leak and now ??? Oh well.
  14. #9
    175 Post(s)
    Quote Originally Posted by Dr Gary View Post
    Would a re-co motor or a swap out from wreckers be more viable than spending more time and $ rebuilding it ?
  15. The Following User Says Thank You to Hodge For This Useful Post:
    Dr Gary (18th April 2019)
  16. #10
    Gold Coast
    The rebuild is similar $$'s to re-co motor. They also fit a new head. I know the rebuilder and they are local. Time is not critical--except I am reduced to borrowing my wife's Territory
    4.2 turnkey is $20k plus, Duramax $40k--too rich for me especially as I do not tow anything.
  17. The Following User Says Thank You to Dr Gary For This Useful Post:
    Hodge (11th April 2019)
