Results 1 to 10 of 11
Thread: Question about radiator
    Mar 2019
    Just a question.
    If anybody knows why this is happening. Radiator coolant is going into the over flow but it's not going back into radiator.
    Had cap changed 3 months ago. It's not running hot at all.
    Thanks ��
    Expert Yeti's Beast's Avatar
    Aug 2016
    Jimboomba
    4 Post(s)
    Quote Originally Posted by Joanne24lillico View Post
    Just a question.
    Thanks í*½í¸
    Hi Joanne
    What type of Patrol do you have?
    If it’s a GU 2.8 diesel then It sounds like a head gasket as that’s what happened to my kids car.
    Has was escaping into the cooling system and pushing coolant into the over flow bottle.
    Hopefully this isn’t the case if yours.
    Proud BTrol Owner
    Mar 2019
    Hi thanks for the reply hope it's not that
    It's a GQ 97 2.8
    May 2016
    8 Post(s)
    are you sure its the right cap ?
    80 Post(s)
    Park the vehicle with the nose up hill and perform this test.
    http://www.nissanpatrol.com.au/forum...l=1#post537609 I'm not sure if the test time needs to be reduced if the engine is a diesel.
    Post #13 of this thread explains how to burp the system.
    Happened to my Patrol not so long ago. Turned out to be the smallest coolant leak on earth which was causing it. So when the coolant was cooling down, air was being sucked in instead of the coolant that was pushed out.
  8. #7
    My mechanic said they "burp" themselves well the 3 ltr Di do.
    I brought a $300 radiator when the head went on mine again
    my mechanic had it pulled apart and the top and bottom tanks re fitted.
    Question ,,,are you losing coolant?????
  9. #8
    Mar 2019
    Not losing any coolant and it's not over heating
  10. #9
    Mar 2019
    Thanks for the info
  11. #10
    Ballarat, Vic
    174 Post(s)
    Along the lines of what Mudski has posted.
    First thing to do - because it is cheap & easy - replace the hose from radiator to overflow bottle.If there is the slightest air leak it will prevent the coolant getting sucked back into the radiator as it cools. Fingers crossed it's that & not a head gasket .
    If changing the hose doesn't improve things test for blown head gasket either as already suggested or take to a mechanic who has a kit to check coolant for combustion gases. (A liquid which changes colour if combustion gasses are present - so shouldn't cost an arm & a leg). Don't do what I did with a previous vehicle & carry on driving around & just topping up the radiator. Result on my motor was the top of the engine block being eroded where the gasket had blown between the cylinders. It was a replacement motor scenario.
