Page 160 of 187 FirstFirst ... 60110150158159160161162170 ... LastLast
Results 1,591 to 1,600 of 1862
Thread: MudRunnerTD's GQ From the Ground Up
  1. #1591
    330 Post(s)
    Shit Heads!!
  2. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    AB (12th February 2019), PeeBee (12th February 2019)
    330 Post(s)
    I grabbed these 2 pics today to show what is welded to the chassis.
  5. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    MB (12th February 2019), PeeBee (12th February 2019)
  6. #1593
    330 Post(s)
    So another job underway.
    I found the receipt in the box. 2015.....
    125mm flexiflares. Bring it.
    6m i cut into 4 x 1.5m lengths.
    I bought some black 10g tek screws and some 12g teks too. I have down flares a few times ans used teks, nut and bolt, washers. Tek screws for the win. Made for this.
    10g for the bulk work and the 12g for the anchors. Also 12g into the scrubbys.
    Perfect width!! STOKED!!
    I need to finish fit the front bar before i can do the fronts but stoked with the finish.
  7. The Following 7 Users Say Thank You to MudRunnerTD For This Useful Post:
    0-TJ-0 (23rd February 2019), AB (24th February 2019), Cremulator (23rd February 2019), jay see (23rd February 2019), MB (24th February 2019), PeeBee (24th February 2019), Reddave (25th February 2019)
  8. #1594
    They’ve turned out really well Darren!
    MudRunnerTD (23rd February 2019)
  10. #1595
    330 Post(s)
    Little more done today.
    Fitted the XR seat to the drivers side using Hurricane adapters. Unfortunately i found the seat mounts had some stress fractures and also the previous guy had ground down the front pins so i had to drill them out of both seats ans replace with bolts. They were hardened and took some bloody drilling.
    Drivers seat in. Passenher seat ready to bolt in but i have more work to the centre console first.
    Drilled another penetration through the roof for the side lights and finished that loom. Pretty happy with it.
  11. The Following 4 Users Say Thank You to MudRunnerTD For This Useful Post:
    0-TJ-0 (10th March 2019), MB (10th March 2019), PeeBee (10th March 2019), Rossco (10th March 2019)
  12. #1596
    330 Post(s)
    Some more done today. All the little stuff now. Closer by the day!!!
    Fitted the rear LED side lights and ran all the wiring.
    Wired up to a switch i the centre console. Fitted the Anderson Plug from the roof to the B Pillar.
    Installed the Centre Console.
    Refitted the door window trims and fitted 1 mirror. The drivers mirror mount has fallen into the door damn it so i have to strip the drivers door inside trim to get to it damn it.
    Mounted the UHF Aerial to the snork.
    Getting close now. Charged the 24v batteries to 100%
  13. The Following 3 Users Say Thank You to MudRunnerTD For This Useful Post:
    Clunk (11th March 2019), MB (11th March 2019), mudski (10th March 2019)
  14. #1597
    I think its been asked. But whats the bilge pump switch for? Just incase you decide to park in a river?
  15. #1598
    330 Post(s)
    I have installed a bilge pump under both front seats. Hoses run up the inside of the B Pillar and pump out of the B Pillar just above glass height.
  16. #1599
    330 Post(s)
    Whats going on here???
    For those mental moments!!
    I know right!! Kool as hell! Mad as faarrkk!!
    The other side next weekend with a switch in the centre console.
    2 x 1100Gal/hr Bilge pumps for the win!!
    Fully Sik!!
    @mudski i have this on each side.
  17. #1600
    330 Post(s)
    How do you run those off 24V mate?
    Hi mate. The bilge pumps are 12V. The only th8ng running off my 24V is the winch and i added an anderson plug so i can run my Engle off 24V too as i only have 1 x 12V battery now.
  18. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    Plasnart (11th March 2019)
