Results 1 to 10 of 10
Thread: Another air con question.
    Ballarat, Vic
    174 Post(s)
    Several months ago on our way north we lost aircon in our car. Turned out one of the aluminium pipes had fractured, probably corrugationsnto blame. We sourced a new pipe & picked it up when we reached Broome, but as yet it hasn't been fitted.
    A couple of questions.
    1. Will leaving the air con system essentally unsealed ( fracrured pipe still in place) have caused any harm to the integrity of the system
    2. The aluminium pipe comes with an aluminium nut on top end & o ring seals at both ends. If I were to fit it myself (far better chance of getting a re-gas whilst I wait than if I need to get them to fit the pipe) should I use o ring grease (silicone grease) on the o rings or fit them dry? And is there a torque setting or can I just tighten them by hand with an open ended spanner?
    Pipe is on passenger side near the top of the radiator.
    Bottom fitting of pipe
    Top of pipe - as currently fitted pipe is bent more than the new one - probably the reason it split
    I would tape up the crack so no dust gets its way in. As for doing the fittings up. I used a tiny bit of engine oil on the seals and just tightened them up until I felt they were tight enough.
    Cuppa (4th February 2019)
    Ballarat, Vic
    174 Post(s)
    Ta ..... better late than never I guess!
    Hardcore jack's Avatar
    Ballarat Area
    25 Post(s)
    Hi Cuppa,
    Just checked with Brad and he said they used compressor oil on the O ring, but silicone grease should be OK.
    He said you’ll save bugger all by doing it yourself. He worked for Field Airconditioning and Auto Electrical in Broome.
    Go and see Matt Field there and tell him Brad sent you, he says Matt is the fairest and most genuine bloke he’s worked with.
    Jack
  7. The Following User Says Thank You to jack For This Useful Post:
  8. #5
    Patrol Freak garett's Avatar
    Jan 2015
    south of the boarder
    19 Post(s)
    x2 on the a/c compressor oil. I wouldn't risk the engine oil, the o rings should be a different composition to the black ones for oils.
    tape it up to keep everything out,
  9. #6
    196 Post(s)
    I think it would be wise to also put a new drier on it at the same time. The desiccant will be saturated now and it won't do the job its designed for. They are not dear from memory, about $100
  10. #7
    Ballarat, Vic
    174 Post(s)
    Any idea whereabouts the drier would be on my car? I see Patrolapart have them for $50.Will have to have a look tomorrow in daylight.
    How do they work? Is it just a cannister filled with a moisture absorber - if so do they need replacing from time to time anyway? Never had anything to do with air con systems before.
  11. #8
    Ballarat, Vic
    174 Post(s)
    Here we go ........... in answer to my own question, what would we do without Mr Google?
    Replace any time the system is opened to atmosphere.
    https://macsworldwide.wordpress.com/...ars-ac-system/
  12. The Following User Says Thank You to Cuppa For This Useful Post:
    PeeBee (5th February 2019)
  13. #9
    196 Post(s)
    Its going to either between the outer plastic grill and the outside face of the nose metal work or on the engine bay side of the metalwork. they are about 50mm dia and 150 long, usually black in colour and might have a smallish sightglass in the top so bubbles can be detected.
  14. The Following User Says Thank You to PeeBee For This Useful Post:
    Cuppa (5th February 2019)
  15. #10
    Ballarat, Vic
    174 Post(s)
    Found it. Drivers side of the radiator. All the replacements I've seen have mounting for the pipes & a single bolt/bung. Original has the same plus an electrical connection which I believe to be a pressure sensor, to prevent the air con running if it loses gas. Have ordered from Patrolapart who assure me the bung can be removed & the pressure sensor screwed in it's place. Suspect perhaps the original receiver dryer had two options for different sized sensors.
  16. The Following User Says Thank You to Cuppa For This Useful Post:
    PeeBee (6th February 2019)
