11th January 2019, 04:41 PM
Patrol Guru
GU 42TDi 12mm pump upgrade
Afternoon ladies and gents. Plenty of good information on here for me to traul through as always.
I've just ordered a 230hp 12mm fuel pump from UFI over in WA and some other bits and pieces including a planned front mount upgrade for the intercooler.
Thought I'd put the shout out and see if anyone has any advice before I start pulling bits off. Any tips and tricks particularly on removing/replacing the pump would be appreciated.
Also if anyone wants to see anything in particular from my upgrade while I'm doing it I'd be happy to follow up on here.
11th January 2019 04:41 PM
11th January 2019, 07:56 PM
Just me but I'd be getting a mechanic with a Dyno to do it , that way you can get it tuned right .
11th January 2019, 08:39 PM
Moderator
Have a look at this thread from post 418 for my Front amount and UFI pump fit.
http://www.nissanpatrol.com.au/forum...he-GUIV-TD42Ti
Check out my Toy -->
Rogue Dung Beetle
15th January 2019, 11:15 AM
Patrol Guru
(Third time I've tried to reply.. not sure if something I'm doing or just not waiting long enough for it to post...)
Thanks fellas. I was always going to take it to someone who knows what they're doing to give it a decent tune. Don't see the point in paying someone to swap out a pump.
I've had a bit of a look at your post MR and looks like there's a lot of info in there. I'll be referencing that for sure once I start pulling bits off and trying to fit my intercooler. Looks like I've got the same one as you only half the size.. I've also only gone 2.5in on the IC side of the plumbing as I was a bit worried about getting it through and around where I wanted it. Hopefully won't restrict things too much.
The parts are slowly starting to arrive!
21st January 2019, 08:00 PM
Patrol Guru
Got a bit done today.. looks like I've got all the hard parts ahead of me.
Thanks again to MR. I reckon you've saved me a lot of headaches when I eventually fit a winch!
For anyone interested..
USER_SCOPED_TEMP_DATA_MSGR_PHOTO_FOR_UPLOAD_1548043298206.jpg_1548043302647.jpeg20190121_155110.jpg
The Following 2 Users Say Thank You to 0-TJ-0 For This Useful Post:
Hodge (21st January 2019), MudRunnerTD (23rd January 2019)
22nd January 2019, 05:22 PM
Rotaredom
0-TJ-0
Technically you are doing nothing wrong, your first two post where reply's 2 Darren's post which contained a link therefor they went into moderation, any posts made by members that have not made 15 posts will get moderated if they contain links 2 websites or email addresses ( even if its in a quoted post ), unfortunately doing so helps us keep some control on spammers.
The Following 2 Users Say Thank You to NissanGQ4.2 For This Useful Post:
0-TJ-0 (22nd January 2019), MudRunnerTD (23rd January 2019)
23rd January 2019, 01:16 PM
Patrol Guru
All plumbed up now except for a few bits i was missing. There's a lot of joins which I'm not super happy about but should be right to get me up and running.
Bit of a hold up on my pump and turbo from ufi but should be here early next week.
23rd January 2019, 07:55 PM
#8
Moderator
Looking good mate. Glad my thread has been helpful.
Just an observation, why have you not fitted clamps to the intercooler piping?? They will blow off for sure!
Rogue Dung Beetle
24th January 2019, 09:42 AM
#9
Patrol Guru
MudRunnerTD
They're on thier way! I had the presence of mind to pre-order the silicon adapters for the intercooler but totally forgot about the clamps to suit! Not a biggy, I ended up needing one more bit of pipe anyway.
In your thread I read someone warning you about the joiners blowing off. Have you had any issues with this? I have one or two joins where I had to cut the pipe (and the rolled bead off) to make it work. I'm thinking I'll need to at least sort those couple joins out with something. In the long run I'd like to take it to someone and have some parts made up in stainless but if I have no issues that'll probably never happen...
24th January 2019, 10:35 AM
#10
Moderator
0-TJ-0
Hi mate, yeah i bought a Pipe and Joiner package off ebay including the good clamps. I still needed a few extras but it saved me a packet..
https://www.ebay.com.au/itm/UNIVERSA...53.m1438.l2649
i cut most of teh pipes to suit my specific needs and cut most of the rolled edges off as they just didnt work. I made a point of keeping everything clean and no WD40 or other contaminants. some of the dry joints where hard to get on but got everything sorted.
When i pumped 25psi+ down them i blow a few f them actually. only where i had used crap clamps though. anything wth the double pull clamps held well. I also used a impact driver with a deep 10mm socket to do the clamps up. Saves a heap of time and worked great. The silicon and decent clamps will be fine i reckon. Holding 27psi to 32psi in 40c all day now mate.
Rogue Dung Beetle
0-TJ-0 (24th January 2019)
