Page 112 of 135 FirstFirst ... 1262102110111112113114122 ... LastLast
Results 1,111 to 1,120 of 1342
Thread: All Things Chev
  1. #1111
    195 Post(s)
    Hi all just talking with a mate who just brought a brunswick diesel GU 6.5 TD.
    he asked me if he needs to laminate the front diff?
    Plus as hes only had it a week it overheated last week when it was hot any suggestion?
    Any imput would be great, TID|A
    I think @MB is your man for the GU as he seems to have his running cooler than originally.
    195 Post(s)
    I was thinking that 8psi may be a bit low. Some of the US guys run 25psi.
    Have you any recommendations from Bullet or BD?
    What will you do for the exhaust?
    Bullet advised me today that 8PSI is the number. They don't see the need for a greater pressure. Flow increase - yes, and they would not give me a number - no idea why - I will ask again. Its getting a bit frustrating right now.
    Have asked the question of both Bullet and Brunswick and both declined or avoided to advise the required flowrate. Pretty annoyed, but now have both of them supposedly wanting to supply a suitable lift pump - will see what I finally find out. Either way, it does not sound like they are putting too much application energy into the selection, more that they are using pumps readily avail in Aussie market.
  4. #1113
    195 Post(s)
    OK< S/C ordered, additional accelerator cable bracket ordered, return fuel line kit ordered, 320HP pump ordered, 8 turbo injectors ordered, just need a TD42 accelerator cable to interchange with the existing.
    Delivery could be before Xmas but depends on availability of the 8 rib pulley sets that are custom for this installation. Looking at filters now, like the look of the K&N washable units, have checked there is a size that will suit the application, circa 300mm long x 150mm diameter x 90 ID, looking for alternate options - think a cylindrical pleated will fit best for me. Air to and from filter box to be 100mm, fed from 100mm SS snorkel.
    MB (12th December 2018)
  6. #1114
    475 Post(s)
    All Things Chev
    Much cooler for its purpose built slow high country stuff now, wouldn’t recommend twin electric fan setups for highway purposes though @threedogs mate.
    I can highly recommend these Thermostat’s (2 needed) as was found so too do many many yanks.
    Video below showing Rainsey on here years back of the difference between Aussie ‘Tridon-82C’ versus Yanky ‘ACDelco-88C’
    https://youtu.be/Z5v9x4FFjng
    FWIW: The US Military specs for 6.5 water temps is 88C minimum to absolute max 125C.
  7. #1115
    Apr 2013
    Upper Ferntree Gully
    22 Post(s)
    Did you end going with Bullet or BD for the kit?
  8. #1116
    195 Post(s)
    I seemed to be getting stuffed around by Bullet, and their past was worrying me, plus BD gets a pretty healthy discount, which he passed on about $400 of saving - no idea what he buys them for but I have his quote and its about $700 cheaper, however as normal, there ends up being a raft of extras that are not included. For example, you need to upgrade the fuel return line and there is a kit for that; there is also a requirement to buy the 'under manifold' throttle kit, plus source a Nissan TD42 throttle cable to mate with it as the HD unit BD supplies with the N/A system wont fit anymore. So I went with BD as they will be my interface with Bullet and BD takes the risk essentially and also has the relationship and knows them better. The s/c will be avail somewhere around jan 14 but could arrive sooner if they put it together and send later this week, Bullet are shut from Dec 21 to Jan 14. I am waiting for confirmation from BD if I will get their side of things before Xmas as they are waiting for the 8 rib pulleys. Bullet have ordered the 8 rib pulley for mine today. On a positive side with Bullet they did send me the PDF of the SC installation instructions.
  9. #1117
    475 Post(s)
    I was thinking of doing exhaust design like this. Which is the same as what Marks 4wd sells for the LS conversions
    Attachment 77111
    Please do pause on that purchase for a bit Ralph mate. Pretty sure my currently shed bound big donk GU has stock zaust manifolds pointing near straight down on the arse end!
    Our GU firewalls are a hell of a lot closer than I too can remember mate :-)
  10. #1118
    195 Post(s)
    I think he was showing more as a concept that actual MB. But good point to mention. I have even less room than you guys so cant do that config. Looking last night at the injectors to remove - holy hell its going to be a mission!
    MB (13th December 2018)
  12. #1119
    195 Post(s)
    Spoke with the VASS engineer today about putting thru engineering once the S/C is fitted and what else needs to be done in preparation. He claims I need to install a diesel particulate filter in the exhaust. Does anyone have experience with these? I did a web check and they are big, restrictive and expensive, yet BD says he gets his for a sell price of $250 each - doesn't sound like the same thing. My vehicle is a 1997, and i would have thought it would be exempt, apparently its a change right across the board. Apart from that, nothing else, no brake test as already done, happy days, just hand over the cash./
  13. #1120
    Apr 2013
    22 Post(s)
    Hi PB that's is correct, get a "100 cell cat" for the least resistance to flow, welcome to the new world we live in......
