Results 1 to 10 of 19
Thread: 1999 Patrol GU Y61 Diffs
    Dec 2018
    Hi,
    Can someone please clarify following:
    My 1999 Nissan Patrol Y61 Wagon ID plate shows Trans Axle info as FS5R30A HG46 and i have yet been unable to get a definitive answer to what diffs are front and back.
    Question:
    Can anyone tell me if BOTH Front and Back diffs are H233B of 4.625 ratios or is there a mix ..... reading weeks of forums has got me confused.
    Hi buddy it might be better to introduce yourself first before asking any questions
    No. harm done its just what the forum asks of us all.
    Welcome any way but pop over to the intro then youll get the answer you need.
    Woof (12th December 2018)
    HG is rear diff = H233B and obviously front and rear ratios are both 4.6
    HH is the designator for the H260 diff
    233 and 260 being the crown wheel dia respectively
  6. The Following 2 Users Say Thank You to the evil twin For This Useful Post:
    MudRunnerTD (12th December 2018), threedogs (12th December 2018)
  7. #4
    Dec 2018
    Thanks for the quick reply evil twin,
    Its about as much info as I can ever get but any chance you know what the Front Diff is ..... is it also a H233B ?
    Reason I ask is I am changing ratio,s in my Y61 and the transmission shop wants me to confirm fit both front and rear before they get started to ensure parts are avail first
  8. #5
    Dec 2018
    Sorry threedogs,
    Not much to tell, I am 59 years old, I have a 1999 Nissan Patrol Y61 GU with a 2" Old man Emu lift kit, 2.5" SS Exhaust and Snorkel and have had the ECU chipped. Truck geared way too much towards high speed highway use and has a very jerky in throttle response in low 4x4. I understand the jerkiness is a known throttle sensitivity issue so I am looking to gear the machine down .....I am happy to cruise at 110 all day rather than 140 (it has standard diameter wheels) and fit a stronger spring into the throttle system ... hopefully that makes it a bit more user friendly in the bush... otherwise the machine is fantastic.
  9. #6
    465 Post(s)
    Front is a H233. H260 only ever came out in the rear diff. H233 has 11 bolts around the centre and H260 has 12 bolts.
    Engism (15th December 2018)
  11. #7
    Dec 2018
    Many Thanks Mudski,
    Your a star.
    Brgds/Ian
  12. #8
    Dec 2018
    Hi Mudski, I just rcvd my H233 diffs from superior engineering in QLD and they have 9 bolt holes ..... any ideas .... it would seem from your note they should have 11 bolt holes .....its such a confusing issue getting specs and really appreciate anything you can add.
  13. #9
    Quote Originally Posted by Engism View Post
    H233 is what you need mate, Can you count the bolts on your housing?
  14. #10
    Dec 2018
    I will n get back to you ... other forums point to 9 bolt is pre 90 and 11 bolt post 90 .... mines 1999 but others say H233 is 11 only .... whats frustrating is I am in the very north of Thailand at the moment ... will get a mate to check the housing bolts
    thks for your time
    ian
