27th November 2018, 09:28 PM
#571
Moderator
Thats a great result mate. What did they have tonsay about it? Where they familiar with the BW? Is that comparison run your run on day one using the other pump? That is nearlly embarassing if thats the best old mate could get from his own pump!!!
Interesting. We should have a chat mate
Check out my Toy -->
Rogue Dung Beetle
27th November 2018 09:28 PM
27th November 2018, 09:58 PM
#572
PeeBee
Good outcome Rossco, did they resolve the fuel tank leak or have you sorted that out?
Yeah they fixed that was the sender. Filled it up again and all good.
MudRunnerTD
Yep comparison was from drive in on old pump, thought it was putting out a little more than that actually. If it weren't for issues i would have been more than happy with it, once it was up & running was absolutely great but down low hopeless and starting issues. Many occasions pulled out into a small gap in traffic and would feel like it was stopped dead then would go once built up a bit of speed, which is not ideal lol.
Think they were pretty impressed, said it was one of the highest powered TDs they'd done, not sure they had much to do with BWs on TDs before. Certainly credit to the Queensland boys and AB for such awesome R&D pretty easy for us to reap the benefits now lol. Been very happy with Cornells too pretty impressive set up over there, clean as a whistle place. .
28th November 2018, 08:25 AM
#573
Bunch of parts have been ordered & en route .
Had a chat to Pirtek just before , showed him some photos of Darren's, Mat's and Andy's fittings for a rough idea of what's needed and he said no dramas.
The ball is rolling !
The Following 3 Users Say Thank You to Hodge For This Useful Post:
AB (28th November 2018), MudRunnerTD (28th November 2018), Winnie (28th November 2018)
28th November 2018, 08:31 AM
#574
The 747
Hodge
Wow no stuffing around mate, nice work!
Hodge (28th November 2018)
28th November 2018, 10:01 AM
#575
Winnie
Yeah mate , the main event is still months away.
I figured I'd put the parts sourcing into action now, and slowly build the stock pile.
Still a bit of homework to do & head spinning, mainly with hose fittings. But it's a start , and the end results i can't wait to see !
28th November 2018, 10:17 AM
#576
The 747
Hodge
There isn't much to it mate, with some tech help from the forum you will be fine to do it mate!
The Following 2 Users Say Thank You to Winnie For This Useful Post:
Hodge (28th November 2018), Rossco (28th November 2018)
28th November 2018, 11:22 AM
#577
Moderator
Rossco
Yeah they fixed that was the sender. Filled it up again and all good. Yep comparison was from drive in on old pump, thought it was putting out a little more than that actually. If it weren't for issues i would have been more than happy with it, once it was up & running was absolutely great but down low hopeless and starting issues. Many occasions pulled out into a small gap in traffic and would feel like it was stopped dead then would go once built up a bit of speed, which is not ideal lol.
Yeah you look like you get a fair bit more earlier than i do actually. I will take a pic of mine and post it here to compare
Rogue Dung Beetle
28th November 2018, 11:25 AM
#578
Moderator
Rogue Dung Beetle
#579
Moderator
Rossco
See above
Rogue Dung Beetle
28th November 2018, 11:29 AM
#580
Moderator
Yeah wow. If those speeds are correct then regardless of the tacho your peaking at 75 to 80kms/h and im just winding up to peak at 90! That is nearly a gear!! Wow
At 70kmh im producing about 100kw and you have 140kw already.
At 80kmh your on boil at 165kw and im just thinking about it at 140kw! I dont see 165kw to about 105kmh. Jesus! Thats a big difference.
Rogue Dung Beetle
