26th November 2018, 02:23 PM
What are good brand air intakes ?
I am looking at a K&N air intake for my TD42 Gq it is 2nd hand for $250 but I can not contact K&N to see how much a new one is to see if it is a fair price
26th November 2018 02:23 PM
26th November 2018, 02:40 PM
Moderator
Do you mean a filter or an airbox? got a pic or a link mate
![Cool](images/smilies/cool.png)
Check out my Toy -->
Rogue Dung Beetle
26th November 2018, 02:48 PM
I used to run a K&N, but now switched to AEM because they're dry and so much easier to maintain https://www.aemintakes.com/search/univcone.aspx.
Steve
2011 Patrol Safari 4.8 (Fitek)
26th November 2018, 03:28 PM
Moderator
Bulbous
Cool are you just chasing a Pod then? i ahve a couple of K&N Filters for a GU TD42 Airbox id be interested in selling as i have changed airboxes and have no further use.
Rogue Dung Beetle
26th November 2018, 05:07 PM
MudRunnerTD
Here is what I was looking at
26th November 2018, 05:10 PM
How do you clean a K&N then ?
26th November 2018, 05:44 PM
Smart like tractor
First Pooy
With Detergent and water.
It's good to have 2 So you can swap them out without the need to give up the car for a few hours
96 GQ coil/Cab
08 G6eT
![](image.php?s=b49173345ffd4f3c788b1706d5d72159&u=1281&type=sigpic&dateline=1483248064)
26th November 2018, 06:23 PM
#8
$250 for air box in pic with pod filter is pretty good (in good condition?) but need 4" thru to be worthwhile. Looks like maybe offset pod filter or outlet pipe set off at angle. Get K&N 9"pod filter (straight flange) for $85-115. Bought K&N (KNRE-0890) today eBay $85.00.
Some more specifics on filter box type/design and pod type?
26th November 2018, 06:58 PM
#9
I didn't know alot about it,I was asking questions but the guy got upset with them it is a 4 inch but now that you have pointed it out yes the out let from the box is on a 45 degree bend is the striaghter the better for air flow,he cliamed he got about 240 hp out of it
26th November 2018, 07:14 PM
#10
First Pooy
The bend is fine, it looks like it provides for good flow. Rule of thumb good idea to have at least 30mm o/a clearance between filter pod outside profile to box internal faces and to not obstruct/causing restriction to the in flow (less obstruction the better. Did he give U a brand name? Does it come with serviceable pod filter?
240 hp require good flow, ask him why he is changing out.
