Page 872 of 1054 FirstFirst ... 372772822862870871872873874882922972 ... LastLast
Results 8,711 to 8,720 of 10540
  1. #8711
    49 Post(s)
    I've got wheel bearing grease, will that be alright?
    175 Post(s)
    How did you go.... I haven't fitted spacers so not much help from me.
    Basically that gap in photo is WITHOUT spacers and is 5mm max. Spacer is 10-12mm.
    Unbolting the arm and pushing diff forward that 5mm fouls on the panhard rod. Does not want to go any further.
    I might have another go tomorrow.
    But, I'm not sure it'll work. Mudski reckons take off the panhard rod on that side, fit arm and spacer and tighten up the rod and see.
    So, weather depending, we'll see what happens.
    Quick google reveals I am not the only one. And the superior product page mentions this as well.
    I'll have a look at mine when I get home from work. I cant see why the bracket would be different from mine to yours...
  5. #8714
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    37 Post(s)
    Mine GUIV 2" lift / 2 Deg caster correction and provides 9-10mm gap/clearance (rod to brkt side face). Do not know your lift / or correction (if any). IMO, if lifted w/o caster correction, clearance would be less. Caster correction lifts caster bush center up therefore rotates axle housing top/brkt to rear increasing clearance between Panhard rod and brkt located on axle housing.
    Forgot : No Radius Arm spacers fitted / or mud flaps... lol.
  6. The Following User Says Thank You to Bidja For This Useful Post:
    Hodge (5th November 2018)
  7. #8715
    175 Post(s)
    I have the castor off set bushes.
    Other than that it's just a basic OME 45mm lift.
    As it sits , it's 5-6mm gap.
    Didn't get a chance to do nothing today , tomorrow won't be much different.
    Jul 2017
    37 Post(s)
    OK, same as mine and similar clearance.
    Do you have adjustable panhard rod? Mine is OEM stock and have noted that the passenger side wheel axle center is positioned approx 40mm closer to the guard face where flap mounts as compared to the drivers side. This could be caused by the lift and the fact that I still have the stock panhard rod. This has not caused any drive or tyre wear issue it just annoys me. I am not sure how the axle alignment changes with corrected panhard rod length to suit lift.
  9. The Following User Says Thank You to Bidja For This Useful Post:
    Hodge (6th November 2018)
  10. #8717
    Been removing some boost since I got the mighty GU back.
    after talking with @mudski decided 25psi was a tad high so trying to get it to about 18psi.
    Still goes like all stink imo egts are low about 150 - 200 degrees
    Plus my mate at Outback 4WD is fitting my rear shock tower bolt on kit [Superior[
    and also fitting an 85ltr water tank ,pump and switched spout to my Hilix tub camper
    That will help balance to camper better.
    Need heaps of jobs done hopefully all before Xmas
  11. The Following User Says Thank You to threedogs For This Useful Post:
    GQtdauto (7th November 2018)
  12. #8718
    195 Post(s)
    Installed a 12V fuel pressure transmitter and gauge between final fuel filter and injector block. Sits at a steady 10psi at idle then holds at 8psi right up to WOT position, which is as expected.
  13. #8719
    175 Post(s)
    No, mine is factory panhard. And looking around the car , everything seems symmetrical.
  14. The Following User Says Thank You to Hodge For This Useful Post:
    Bidja (6th November 2018)
  15. #8720
    49 Post(s)
    After putting the streeing box back together I left it alone. Today I went for a 15min drive focusing on turning. Got back and had a look.
    Dry.....
  16. The Following 3 Users Say Thank You to jay see For This Useful Post:
    GQtdauto (7th November 2018), mudnut (7th November 2018), threedogs (7th November 2018)
