Page 868 of 1056 FirstFirst ... 368768818858866867868869870878918968 ... LastLast
Results 8,671 to 8,680 of 10551
  1. #8671
    Wasn’t today but Sunday. I had to replace the reverse camera on the small barn door. So while I was at it I made up a new plastic seal thingo for the door, sikaflexed up any holes in the door to try and stop the exhaust leaking into the cab. Didn’t work though. I also removed the inner door handle.
    Now to find where this exhaust leak is... I have to drive with the air on recirculate all the time otherwise when I stop moving I get a nose full of exhaust fumes.
    Sent from my crapPhone using Tapatalk
    Back seat bolt holes maybe...i put mine back in after removin third row seats
  2. The Following User Says Thank You to Avo For This Useful Post:
    GQtdauto (30th October 2018)
    175 Post(s)
    Could it be coming from the front somewhere ?
    When my EGR pipe cracked on the old patrol it was pretty evident inside .
    Yours be at turbo maybe or manifold ...
    Yeah I'm begining to think this. I will have to take a closer look towards the front.
  6. #8674
    80 Post(s)
    I have recently serviced both front hubs, but had a bit of a parking mishap last week, where the front left tyre hit the gutter a bit harder than normal. The dreaded wobbles at around 80ks were just starting to occur, so I checked the bearing for movement and sure enough, I had to nip up the pre-load a fair bit.
  7. The Following User Says Thank You to mudnut For This Useful Post:
  8. #8675
    Advanced Finezy's Avatar
    Geelong - VIC
    3 Post(s)
    Gave the old girl a very overdue bit of TLC, she was looking pretty sad for a while.
    2001 GU II ST, 3.0di, Auto, All NADS done, Nissan Snorkel, 50mm Lift, 35's....
  9. The Following 3 Users Say Thank You to Finezy For This Useful Post:
    Bob (31st October 2018), GQtdauto (31st October 2018), MB (31st October 2018)
  10. #8676
    Patrol God Bob's Avatar
    Oct 2010
    Pakenham
    47 Post(s)
    Quote Originally Posted by Finezy View Post
    Smicko …..
  11. #8677
    Same as the last 3 nights after work.
    Diff oil change. Getting better
  12. The Following 4 Users Say Thank You to jay see For This Useful Post:
    Hodge (1st November 2018), MB (31st October 2018), mudnut (31st October 2018), rusty_nail (1st November 2018)
  13. #8678
    hows the seal around your gear stick? probably the biggest point of entry near to the exhaust?
  14. #8679
    All fairly new too...
  15. #8680
    Expert Yeti's Beast's Avatar
    Aug 2016
    Jimboomba
    4 Post(s)
    Changed both my engine mounts last night. Can’t talk about it as I’m still too traumatized by the experience
  16. The Following 4 Users Say Thank You to Yeti's Beast For This Useful Post:
    GQtdauto (1st November 2018), MB (1st November 2018), mudnut (1st November 2018), PeeBee (1st November 2018)
