Results 1 to 8 of 8
Thread: ZD30 CRD - Injectors ticking noise
    Sep 2018
    Hi all,
    The fuel injectors on my GU6 (2009) ZD30 CRD make a loud(ish) ticking noise. I took the car for servicing and asked the question, the mechanics' answer was "it's pretty standard on them". Still, it kinda bothers me.
    It's more noticeable when engine is hot, when standing next to the engine bay when idling, it's quite obvious. It's also heard from inside the cabin when pushing the throttle.
    Should I not worry about it or what else can I do?
    124'000 kms on clock.
    175 Post(s)
    Does it sound like your standard diesel " ticka tacka ticka tacka" sound ?
    I used to own a 2009 crd patrol. And if you listen closely , for example have your ear close to the top motor , the diesel injector chatter is very very apparent.
    Sep 2018
    queensland
    leak back test would show signs of an injector not performing. could start there.
    Sep 2018
    Yes, I would say so. It's the first diesel I own so I don't really have a point of comparison.
    I didn't notice any malfunction or under performance though, but the ticking is very apparent.
    175 Post(s)
    My money is on this.
    They have a distinct injector sound as do d4d Toyota motors.
    Quote Originally Posted by jrm456 View Post
    Sep 2018
    Thanks for the insight mate. If it really is standard I'll just live with it
    465 Post(s)
    Get the mechanic to check/ adjust tappets. What oil are you using? I found in my old 3Ltr Castrol Magnatec Diesel was the best to quieten things down in it. Plus a service every 5thou...
    Legendary happygu's Avatar
    Mine used to do it too, and coming from the Di where you couldn't hear it, it was a little disconcerting at first. I am trying to remember back before I installed the chip, and I think mine was only really noticeable at a certain rev range after you had backed off the throttle a little
    The noise has disappeared after installing the Unichip and retune, so I can definitely confirm it is injector noise
