Bought one of these for the Y62.
Looks are subjective but I like the display etc more than the Scan-gauge.
Works as advertised so far.
I'll see how I go with the Mgauges for Engine Oil Temp and Auto Tranny Temps... many Beers may be needed...
I dont care. Can you get a unichip and tell me your thoughts?
Show me your Y62.....
Hehehe... in order...
I don't care that you don't care but if the Beer runs out shit could get real.
Yes, I can get a Unichip, we have the Internet over here now
My thoughts... Pollies suck, we should all eat more red meat and Global Warming is a crock
No, if you've seen one Y62 ya seen 'em all
Avo (25th September 2018), GQtdauto (25th September 2018), nissannewby (25th September 2018), Plasnart (25th September 2018)
I got the expensive exhaust and can tell you its great. Im stuck on what to get next whether it be the front bar, lift or unichip.
ET, I've had the Ultra Guage for the last couple of years and besides a bit of frigging around to get the mileage readings to be accurate, it has been great. Nice big screen with lots of display options. Have even used it a few times to reset codes too.
No, only an under-boost warning when I popped a vacuum line off and then another warning code when I got water in a sensor after a very deep crossing. Never found that one as it must have dried out overnight.
With the fuel / mileage calibration - it might be the same thing with the Scanguages (not sure), but after measuring wheel diameter and entering that, I then kept adjusting it for about ten fuel-fills using GPS for distance. My speedo is still out since changing wheel size to 285/75 so couldn't rely on it.
On my front guage face (page 1) I monitor fuel average, engine water temp, air intake temp, fuel level in the tank, total fuel used on a trip, and voltage as read from the ECU. I have also set it up with the alerts for oil changes to be done at 5000klm but haven't really bothered with many of the other functions.
My front page will probably be 4 gauges - Speed, ECU Volts, Engine Oil Temp and Tranny Temp when I get them going...
the evil twin (27th September 2018)
