7th September 2018, 06:15 PM
7th September 2018 06:15 PM
7th September 2018, 07:00 PM
Dumb question mate, but is that oil or diesel ???
Just doesn't look "black" enough to me, but i could be wrong.
Looks like diesel mixed with gunk/dirt... If so, it could be going past the injector washers/seals.
7th September 2018, 11:08 PM
Hodge
Hi Hodge,
It’s funny you say that because I thought the same thing today. I had it running and noticed the #4 injector had a clip on it that was rattling. It made me think that something must be loose one there and it could be Diesel. That could explain why its absolutely every where
. Would that mean a buggered injector? Or still just a seal?
Not a dumb question at all mate. Cheers.
8th September 2018, 09:27 AM
in my personal experience the oil in the 4th injector area is from the cracked intercooler and the oil drips into #4 injector my zd30 crd did it until i brought a welded intercooler. i read you have one though..
i cant see why only one injector seal would leak, plus i think that yours is CRD meaning the injectors seals are apart of the whole rocker cover and that $$$$ from nissan. dont think non genuine do just a seal either (if anyone know if non gen do let me know
blocking the egr without dawes valve could be causing higher boost (maybe to be confirmed by others as well) and that might be forcing the oil mist out easier.
air filter looks about right i wouldnt worry on that one, ive been told thats normal, the first part the air contacts ends up really dirty just leave that part facing the opening dont spin it around to a cleaner part.
i also read you have a catch can. what brand? also keep in mind catch cans no matter the brand wont prevent that oil mist from entering the intake 100% but removing even half helps. (is the catch can plumbed in correctly are you finding it catching oil?)
lastly you intake pipes look factory i've seen afew get splits in them i would recommend forefront industries pipes if you have splits as genuine is $$$$$
https://www.forefrontindustries.com.au/gu-patrol
have a look here and see what fits you car, as Di and CRD have some differences.
8th September 2018, 10:48 AM
2keen
Hi Hodge,
![](http://s3.amazonaws.com/tapatalk-emoji/emoji848.png)
Unsure mate. First thing I thought was leaking intercooler but as I read it you have a new welded unit so ... Slim chances of that leaking.
Degrease the whole lot and then keep an eye and see where it's coming from.
If it's fresh diesel it'll.smell like diesel.
8th September 2018, 12:46 PM
I am he, fear me
Air Filter - common to look like that? Yes... after 5000 K? Nah, looks excessive esp if the EGR is blocked.
The gunk is deposits from Turbo Surge (high pressure charge air surging back thru the Turbo from the Cooler when you back off).
It is essentially the same gunk that weeps out from non-welded intercoolers and induction pipe joints.
When the Turbo is at high boost all the charge air is engine bound but when you back off sharply with a VNT Turbo the Boost drops very quickly.
That boosted air in the I/C and pipes can't all get to the engine now and some flows back thru the turbo towards atmosphere and deposits the gunk on the filter
The Following 2 Users Say Thank You to the evil twin For This Useful Post:
Hodge (11th September 2018), timmay556 (30th May 2019)
30th December 2019, 08:17 AM
Hi 2keen,
How did you go with leak? I have a CRD and have just found that mine is leaking in the same spot. Any advise would a big help.
2016 Dessert Gold ST Patrol Wgn Manual CRD, Flash Lube pre filter, Flash Lube catch can pro, pillar pod, redarc egt boost + voltage gauges, scan gauge 11, dawes and needle valves, safari snorkel, 3" legendex stainless exhaust, couplertec and underbody rust protection
30th December 2019, 01:32 PM
#8
IMO change the air filter out(it is crap design anyway), remove the ducting from airbox to turbo, give it all a good clean, inspect and re-assemble making sure all joint faces are clean and dry. Then wash down engine clean and observe.
15th January 2020, 05:09 PM
#9
2keen
..oil leak
sooty
Hi 2keen,
Same here, would be curious how the leak is going as the same thing happened to my CRD at the same spot.
Just yesterday I replaced my intercooler with a new JayRad welded one and haven't had a chance to clean up properly and see how it goes. Will also replace the seals and hopefully that'll fix it.
2012 CRD 30TD Auto Wagon, 15L/100km | 2" KYB Lift | 3" Exhaust | ECU Remap | HPD boost control | Provent Catch Can | EGR Block | Bullet Snorkel | Dual Battery | Redarc SBI12 | Projecta batt Monitor | Auto Headlights | iDrive Throttle Control | NU3001 7" Android Stereo | Sound Deadening| Reverse Camera | Dashcam | Amp, 12" Sub | 300W Inverter | USB Chargers | Barn Door Gas Strut | Awning | Mods list shrinking
![Bananadancing](images/smilies/bananadancing.gif)
30th January 2020, 10:40 PM
#10
What you're seeing on the airfilter is pretty normal.
The air supply into the airbox only focuses on a small area. If you don't have a new air filter handy you can rotate it 90-180 degrees so the fresh air blows against a "cleaner" spot.
