Results 1 to 10 of 14
Thread: Scan tools
    Aug 2018
    Scan tools
    Hey guys new to the forums.
    I own a 3L DI gu patrol and having some issues with it running. I have used a foxwell NT200 and also a Actron CP9576 but they dont seem to work on my 3l DI. Does anyone know a good scan tool to use or to buy that can actually work on a DI? Cheers, this is my rig atm 39467585_275708943247578_4118958973569204224_n.jpg
    465 Post(s)
    Dunno if 4x4 SC still sell one, but theirs works on a Di.
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    37 Post(s)
    Mark, was this the EDS tool from Berrima Diesel _ OBD11 compliant?
    Jul 2017
    37 Post(s)
    Quote Originally Posted by Craig Mc View Post
    Craig, the ECU Talk scan tool is widely used for non-CRD ZD30DDTi. Check the diesel compatibility list on the attached link. It also explain the configuration of the Nissan Consult protocol (14 pin connector) pre CRD.
    http://www.ecutalk.com.au/diesel.aspx
    These have USB interface also.
    465 Post(s)
    Ahh yes it was too. ECUtalk as you mentioned is the correct tool for the earlier Di's.
    Patrol God Bob's Avatar
    Oct 2010
    Pakenham
    47 Post(s)
    I have a Nissan Consult for pre 2000 Patrols together with ECU Talk Software.
    See Screen Shots here http://www.ecutalk.com.au/screenshots.aspx
    Free to good home.
    Pick up in Pakenham
  8. The Following User Says Thank You to Bob For This Useful Post:
    Bidja (20th August 2018)
    Jul 2018
    Hi Bob, would this work with a 2000 GU with a 4.8 petrol eng? Mine is surging and flat spotting just off idle & is intermittent & would like to do live data. Thanks - Leigh
  10. #8
    Oct 2010
    Pakenham
    47 Post(s)
    Quote Originally Posted by LeighC View Post
    @LeighC
    Yes I believe it will.
    If you want to bring it around it will take 5 minutes to hook it up to test
    Regards
    Bob
  11. #9
    Jul 2018
    Thanks Bob,
    I have been told I need Consult II, I have an OBD2 plug under the dash but it doesn't appear to talk the later language.
    Its a bit hard to bring it around as I am in Northern Vic above Shepparton, I do know a guy who lives in Dandenong that I may able to get him to pick it up, is that close to you?
    If it doesn't work he could drop it back, he drives a car carrier & comes up regularly. I could send you a prepaid postage bag would that be OK?
    I would like to get to the bottom of it really because my next step is a new TPS & that is expensive for an auto trans. as you have to buy the whole throttle body with motors & so forth, the vehicle has done 300K so it could be getting worn in the resistive pots. I do not have a check engine light on & the Nissan dealer cant find anything, have fitted a new MAF sensor & 2 oxy sensors, done the valve shims, set the timing, done the 3 throttle relearns & still has this intermittent lean mixture just off idle & it even mucks the auto changes up when it happens, other than that it drives perfect 90% of the time.
    Cheers for your help- Leigh
  12. #10
    49 Post(s)
    Bob if it doesn't work with @LeighC I'll grab it, my Patrol is what you had.
